Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-26-2007, 01:14 AM
drpepper is starting off with a positive reputation.
Cool running issiues
I have a 1990 bronco 2 when i bought it it had some lifters tapping so i parked it for a while , starting it perodicaly when i finally decided to break down and replace the lifters it would turn over and try to start but would not run. acted like it wasn`t getting any gas but checked my fuel pressure which was perfect . i went ahead and replaced the lifters , rebuilt the distributor , replaced plugs and wires and it still won`t run .. it tries to crank up and run but unless i constantly pump the throttle it won`t even attempt to run , thought maybe the fuel pump had gone so i replaced that , still no luck , now after replacing thwe fuel pump the fuel rail does not seem to be holding pressure and it still won`t run , tried replacing the pressure regulator , (took it off of my other bronco which runs) still no luck .
anyone got any ideas i`m about at my wits end trying to figure this out.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-02-2007, 12:52 PM
Twistin's Avatar
Twistin is starting off with a positive reputation.
Did you get it running yet? I have 90 bronco II and have been thru the 2.9 engine. I might be able to shed some light on the subject. Keep Em' Twistin'! Bob B
  #3 (permalink)
Old 11-03-2007, 10:13 PM
no did not get it running yet , but found that my problem is more than likely in the head gaskets or the lower intake gasket will know more once i run a compression test
  #4 (permalink)
Old 11-04-2007, 12:21 AM
Twistin's Avatar
ok, did you seal the back part of the intake? there's a "gap" back there that you seal with silicone. If you didn't then you have a major vacuum leak. #2 did you pre pump the lifters? they might not be totally pumped up. when my 2.9 had a plugged oil pick up screen, it would dump oil pressure, and tick like crazy until the point at full throttle it would barely idle. (collapsed lifters).
By pumping the throttle all your doing is giving it more air. the injectors are what gives it fuel. make sure when you put the fuel rail back on that all the O rings are in place, and or arn't cut. also that the rail is properly seated down all the way. also check and make sure that the plugs that go on the injectors are all plugged in correctly. to check fuel pressure at the rail, cycle the key on/off then go to the Schrader vavle and press it. fuel should "spray" out. if it only dribbles out then your not getting proper pressure. could be your fuel pump relay or even a a simple thing as a plugged fuel filter.
That will give you a few thing to check. if all that is ok then give me a holler back.
Keep Em' Twistin' Bob B.
____________________________________
Bronco's 89 thru 96 / XLT / Eddie B / BR II
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
