new here, have 1956 f100
around 2k then? for those kind of numbers ? first bake the engine/bore is , pistons 500bucks 180bake/bore 150/500bucks for the pistons 830? clean the heads and then a new intake manifold? and maybe a new carburator after a while. but one question since the owner before me welded mounts to the body the 460 engine wont bolt in its 3/4inches away from bolting in? anyway for help?
the oil pan its to big and wont fit in ya i know im from the dark side, not my fault the guy put a gm/nova front base and rear end- hence the reason i need a mustang rear end- something more capable of not shattering =] but i dont want to spend like 290 for a low profile oil pan when i can just take out the motor mounts and weld new ones in? is their a thing i can buy that has taller mounts?
Might want to look at different oil pans. If you just raise the motor so that it doesn't rest on the cross member it might have your motor running uphill or high in the front. This might not be the case as I am not familiar with the subframe you are running, it could be that you just need to raise the motor mounts to get it to sit in there level and it won't be resting on the oil pan. If you could show pics as you go I for one would really like to see and would appreciate it. I think this is why alot of guys run SBCs when they use a chevy subframe, its just easier.
thanks for the info yeah i will def keep u updated on my project- this is a great site for people that know a hell of alot more then me- heck im 19 and just wanted an old truck with a big block.... we put old chevy malibu big block springs and stuff it fit and mounted up and the springs worked wonderfully, just putting those suckers in was scary and hard even with a compresser. me personally is true 100% ford freak.... i got my friends into it too. um if u guys got ideas.... tips their def appreciated.were getting the engine stand tommarow and taking peice by peice off to get the block boiled and cleaned and checked for cracked anything.... so yah keep ya updated.
#29
#30
