2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Trans and Engine Oil Temp Gauges
Old 10-25-2007, 10:08 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
Has anyone installed any of these? Where did you find space to put the gauges?
Thanks,
Rich
Old 10-26-2007, 07:42 AM
myexpo02's Avatar
myexpo02
myexpo02 is offline
I would like to see a nice setup for the Trans myself. I think it would be the most useful of any guage.
Old 10-26-2007, 02:46 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
I've asked the question in the fourm already and posted a response to your engine oil cooler post. The data is in the ECM, but you must have a compatible code reader to display the extended data. For Expedition I found a couple of options, but haven't tried any. I wanted to use the Edge Evoultion programmer & gauge, but it does not work for the 2007 Expedition (5.4 F-150 ONLY).
You might want to checkout:
www.scangauge.com
www.dashhawk.com
http://www.aeroforcetech.com/Fordtech.html
Old 10-30-2007, 07:55 AM
rich93cw's Avatar
rich93cw
rich93cw is offline
[QUOTE=07EXPYEL]I've asked the question in the fourm already and posted a response to your engine oil cooler post. The data is in the ECM, but you must have a compatible code reader to display the extended data. For Expedition I found a couple of options, but haven't tried any. I wanted to use the Edge Evoultion programmer & gauge, but it does not work for the 2007 Expedition (5.4 F-150 ONLY).
www.scangauge.com
www.dashhawk.com
http://www.aeroforcetech.com/Fordtech.html[/QUOTE]
Great list! Looks like only the DashHawk will read both trans oil temp and engine oil temp on Fords. Looks like a great tool for $299. To bad its not discounted somewhere yet.
Thanks,
Rich
mdwirth
12-22-2016 09:00 PM
Boss7116
07-08-2015 02:58 PM
remmers
33
12-09-2010 01:40 AM
dj53
01-24-2006 01:20 PM
78bronco
05-03-2002 05:25 PM
Quick Reply: Trans and Engine Oil Temp Gauges
