2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Differences
Old 10-21-2007, 06:53 PM
azlandshark's Avatar
azlandshark
azlandshark is offline
Differences
Does anyone know the differences between the Police package and the regular expedition. I am assuming bsides the interior changes, there is a oil/tranny/PS cooler and the speed governor allows for higher speeds. Any HP differences I would assume to be minimal as that thing is a beast anyways.
Old 10-22-2007, 07:33 AM
gristanv's Avatar
gristanv
gristanv is offline
Check this link:
https://www.fleet.ford.com/showroom/...editionSSV.asp
Old 10-22-2007, 07:38 AM
gristanv's Avatar
gristanv
gristanv is offline
Sorry it won't work.
Please try to go
You will find Expedition SSV
Old 10-23-2007, 05:24 PM
azlandshark
I tried there, What im looking for is more of the inside info. The agnecy I work for is looking to purchase an expedition, to replace our old one which after 202k is pretty much on its last leg. Im trying to figure out if the SSV expeditions have upgraded brakes, oil/tranny cooler, and so on. From what I can tell the engine is the same, trans is the same, no 3rd row seating which is fine, no center console. I saw it has a heavy duty radiator and trans cooler, which comes with a tow package anyways. If this was a charger I would know the differencs really...sigh
Old 10-29-2007, 04:30 PM
IQ9's Avatar
IQ9
IQ9 is offline
Hope you are not looking at getting the EL. I have an 08 and it needs all of the 300 hp & 365 tq to move in fact it could do with another 30 in both figures.
Old 10-29-2007, 10:15 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
There is no difference between the SSV and the standard expedition as far as drivetrain. You need to check out the michigan state police test, they do a battery of tests on each vehicle. As far as larger coolers, the SSV uses the same coolers as a expedition equipped with the HD tow package. Everything else is the same save the cheap interior. Brakes, suspension, etc, I would however be interested to see how much, if any difference the 20" wheels make in the braking and accel tests.
Old 10-30-2007, 01:16 PM
azlandshark
Thanks for the info.
wmiller
05-16-2016 10:28 AM
Jointasset
03-15-2016 05:00 PM
Pgh Rebel
2004 - 2008 F150
12-26-2015 11:05 PM
fifty-two_f1
04-11-2015 11:06 PM
flipklos
05-20-2010 05:14 PM
Quick Reply: Differences
