fuel mixture - too rich
hi there, i have a 88 f150 with a fuel injected 300i6, what would cause my truck to run too rich. i'll take any sugestions, i;m a courier driver and i prefer not to spend 50 bucks a day on gas. It was running good until i put some injector cleaner in it. I also cleaned the throttle body
thanks in advance
Allan
thanks in advance
Allan
ok, no i'm confused, drove the truck this morning and it seem to run normally. i'll run it for the day tommorrow and see how it goes. i will change the o2 sensor anyways, i don't think it's been changed for awhile
by the way, love the site, it has tons of usefull info, keep it up
thanks
Allan
GO ESK GO
thanks
Allan
GO ESK GO
well, i broke down and took it to ford. Theyhooked up to the computer and it was the sensor that is basically the thermostate. i'll try that. it makes sense, if the truck thinks that it's -30C outside then it will run rich till the truck gets to proper op temp, which it doesn't.
Allan
Allan
got it fixed, it was the ECT sensor, 200cdn later and the truck runs a lot better. Next thing to work on is the hi idle, got none. I talked to the mech and he said it's the TPI / TCI thing. The best thing they normally do is just clean them, will do on sat.
once again thanks for all the help and ideas
Allan
Allan
oldmerc
02-05-2012 01:31 AM
hotroddually
15
09-23-2009 02:43 PM
aj197816134
02-21-2007 09:42 PM
