fuel mixture - too rich - Ford Truck Enthusiasts Forums
Old 11-24-2002, 08:54 AM
AL88 AL88 is offline
AL88 is starting off with a positive reputation.
hi there, i have a 88 f150 with a fuel injected 300i6, what would cause my truck to run too rich. i'll take any sugestions, i;m a courier driver and i prefer not to spend 50 bucks a day on gas. It was running good until i put some injector cleaner in it. I also cleaned the throttle body
thanks in advance
Allan
Old 11-24-2002, 03:01 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Probably coated the O2s in the carbon from the engine- I'd replace that. If you are good at soldering, a universal O2s goes for something like $20-40.
Jared
Old 11-24-2002, 03:23 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
I'm not sure if a bad FPR could let more fuel, or a higher pressure than normal, through or not.
Old 11-24-2002, 04:53 PM
ok, no i'm confused, drove the truck this morning and it seem to run normally. i'll run it for the day tommorrow and see how it goes. i will change the o2 sensor anyways, i don't think it's been changed for awhile
by the way, love the site, it has tons of usefull info, keep it up
thanks
Allan
GO ESK GO
Old 11-25-2002, 06:53 AM
Stephens Stephens is offline
Stephens is starting off with a positive reputation.
I like replacing the 02 sensor suggestion, they are recommeneded for replacement at 50k miles. But everyone seems to get 80-100k miles out of 'em. Also, a really dirty air filter can cause a rich condition.
Old 11-26-2002, 11:40 PM
well, i broke down and took it to ford. Theyhooked up to the computer and it was the sensor that is basically the thermostate. i'll try that. it makes sense, if the truck thinks that it's -30C outside then it will run rich till the truck gets to proper op temp, which it doesn't.
Allan
Old 11-28-2002, 07:47 AM
got it fixed, it was the ECT sensor, 200cdn later and the truck runs a lot better. Next thing to work on is the hi idle, got none. I talked to the mech and he said it's the TPI / TCI thing. The best thing they normally do is just clean them, will do on sat.
once again thanks for all the help and ideas
Allan
Old 11-28-2002, 10:53 AM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
T5 Adaptors oldmerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 03-27-2012 09:02 PM
I think I found my next project oldmerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-05-2012 01:31 AM
Mark Martin is the Man !!!victory again hotroddually General NON-Automotive Conversation 15 09-23-2009 02:43 PM
truck running super rich albung 1987 - 1996 F150 & Larger F-Series Trucks 37 03-11-2008 08:07 PM
electrical Woe's aj197816134 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 02-21-2007 09:42 PM
Tags
300, f150, ford, fuel, inline, mix, mixture, rich
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
