removing trim around rear window? - Ford Truck Enthusiasts Forums
Old 10-25-2007, 12:04 PM
canucker canucker is offline
canucker is starting off with a positive reputation.
Can someone please provide some advice how to remove the trim around my rear window.Do you just pop it off somehow?
Old 10-25-2007, 01:47 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
If I remember right, there are bolts holding it in from the inside. Hopefully someone will be along shortly to give you better details.
Old 10-25-2007, 02:08 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Yeah you have to take the interior apart(headliner, trim pieces, etc.) then there are studs you undo, and it should come off. Im resealing my back window this weekend(4day weekend!) and trading out my trim piece for one that isnt faded.
Old 10-25-2007, 07:11 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Green is glass bolts, yellow is trim bolts. You have to remove the glass to remove the trim.
Old 10-25-2007, 11:38 PM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
Thanks for the photo, I'd like to put a sliding rear window in & just saw an ad for 1, but never considered how they were installed. Wouldn't happen to know if the 1 piece rear window installs w/the same 12 screws?
Does the glass come out from the inside? Can I presume you can replace the glass & seal from inside w/o even disturbing the trim?
Old 10-26-2007, 04:13 AM
ncranchero's Avatar
Same bolts for both type glasses. The glass & trim are removed from outside once the nuts are removed. Too bad you're not closer, I'd swap you my slider for your 1 piece glass!
Old 10-26-2007, 06:15 AM
Bobby82490's Avatar
I took the back window and trim out of my parts truck without taking out the trim, i just pulled it back and unbolted it. But i highly recommend taking out the trim, after i got the window out the trim and headliner looked like crap. It shouldnt take too long to take the trim out(1 hour?). I got to take all my trim out this weekend so i can reseal my window. Also when you get your new window get the window sealant. I just got 15 feet(enough to do the back window) of butyl tape from napa for like $15.
Old 10-26-2007, 06:45 AM
ncranchero's Avatar
I'd get the parts listed at the bottom of this TSB if I were going to the trouble of removing/replacing my back glass.......
TSB # 01-1-11
http://www.ford-trucks.com/tsb/fullt...hp?tsb=01-1-11
Old 11-04-2007, 12:58 PM
JOE SKI JOE SKI is offline
JOE SKI is starting off with a positive reputation.
ncranchero..thanks for the pics and the link...my '97 f-150 window is leaking also...what a pain getting the vinyl pieces off in order to get at the nuts! I used a long screw driver and bent a fish-hook in it to release the metal tabs, now to repair the cracked plastic frame(junk!)
Old 11-09-2007, 10:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
after removing the interior trim, can you take the outer trim off without removing the window? what comes off first, trim or window?
Old 11-09-2007, 11:04 PM
__________________
ncranchero shows a picture in the above reply . I didn't remove either since I just put a bandaid on it for now.
Joe Ski
Old 11-09-2007, 11:12 PM
steve(ill)'s Avatar
i saw the picture and it says the trim comes off last, but i cant find anyone who has removed the window and trim and can confirm that you can not get the trim off first..
Old 11-10-2007, 10:03 AM
02crew's Avatar
02crew 02crew is offline
02crew is starting off with a positive reputation.
yes you can steve. there is no lip on the glass or the slider that would not allow you to remove the trim and not the window. peolpe 9 out of 10 times are removing the window to replace or reseal so the trim gets no attention (he he) but like our pal bobby i bet alot of us are going to be pulling the plastic trim and painting them. there is noting worse that a nice looking truck with that stupid faded grey plastisc trim around the window. what do you guys think? gloss back to match the window or body color match?? anyone ever do this yet? pics please
Old 11-10-2007, 10:31 AM
montanafordman's Avatar
montanafordman montanafordman is offline
montanafordman is starting off with a positive reputation.
does anyone know if there is a good way to refinish or buff the faded window trim? Mine's faded too but I'd rather not go through the trouble of getting it out and painting it or replacing it.
Old 11-10-2007, 10:41 AM
02crew's Avatar
i used some turtle wax ice (paste) on mine bit it wasnt too bad to start with. ild try some wd40 on a rag. i dont think anything will be a perminent fix.
'99 F150 Rear Window Trim, where to find Moldylizard 1997 - 2003 F150 6 10-18-2015 07:13 PM
rear window chrome trim '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 0 08-09-2015 07:01 PM
Rear sliding window, remove? newfordy 2009 - 2014 F150 10 07-12-2015 02:09 PM
big back window trim Smirks90 1957 - 1960 F100 & Larger F-Series Trucks 2 06-10-2015 01:02 AM
Rear window trim G_MAN Appearance & Dress-Up 3 01-22-2002 03:56 PM
Tags
2005, 9704, 99, back, butyl, f150, ford, glass, ranger, rear, removing, sliding, tape, trim, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
