removing trim around rear window?
#32
Found out mine was leaking yesterday morning. This will save me some money. Thanks
More info http://www.fordf150.net/forums/viewtopic.php?t=78743
#33
#35
this might be what I have to do since I work at a dealer. at least the price should be a little bit cheaper. I haven't had much luck looking for the piece itself. everybody is trying to sell the glass.
#36
Do you by chance have a part number for this? Mine is broke to hell also and would like to replace it. I think I am getting water intrusion from where those bolts go through.
#37
hey, did you ever wind up replacing the trim with a new factory replacement? I am at that point and have to spend the $400+ to stop the leak it seems. If you did, do you remember if the sealing gasket that comes with it looked much different/improved over the original version? Did the new piece solve your leak problems? Thanks.
gumshoe
18
04-26-2023 09:38 AM
K. M. Thompson
08-12-2017 09:10 PM
Zach M.
02-16-2017 06:22 AM
Serfbored
11-14-2016 09:28 PM
