removing trim around rear window? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-10-2010, 02:25 PM
notfromaroundhere notfromaroundhere is offline
notfromaroundhere is starting off with a positive reputation.
ok...here goes nothing...now i am right close to you [hendersonville, nc] if you are still hankering for used 1 piece backglass
  #32
Old 10-26-2010, 09:40 PM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
Found out mine was leaking yesterday morning. This will save me some money. Thanks
More info http://www.fordf150.net/forums/viewtopic.php?t=78743
  #33
Old 08-28-2014, 07:31 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
so does anyone know where I can find the plastic trim piece around the window? a couple of the brackets on mine are broken. I'd like the have all of the parts before I tear it apart since this is my only vehicle.
  #34
Old 08-28-2014, 09:31 PM
dblake37's Avatar
dblake37 dblake37 is offline
dblake37 is starting off with a positive reputation.
I bought one at the stealership $3-400 I think. Too much for what it is, but mine was faded and broken also.
  #35
Old 08-29-2014, 12:29 AM
Dr. Dirt's Avatar
Quote:
this might be what I have to do since I work at a dealer. at least the price should be a little bit cheaper. I haven't had much luck looking for the piece itself. everybody is trying to sell the glass.
  #36
Old 02-17-2015, 01:34 PM
robkelley13 robkelley13 is offline
robkelley13 is starting off with a positive reputation.
Quote:
Do you by chance have a part number for this? Mine is broke to hell also and would like to replace it. I think I am getting water intrusion from where those bolts go through.
  #37
Old 11-26-2016, 12:44 PM
FordLou FordLou is offline
FordLou is starting off with a positive reputation.
hey, did you ever wind up replacing the trim with a new factory replacement? I am at that point and have to spend the $400+ to stop the leak it seems. If you did, do you remember if the sealing gasket that comes with it looked much different/improved over the original version? Did the new piece solve your leak problems? Thanks.
'99 F150 Rear Window Trim, where to find Moldylizard 1997 - 2003 F150 6 10-18-2015 07:13 PM
rear window chrome trim '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 0 08-09-2015 07:01 PM
Rear sliding window, remove? newfordy 2009 - 2014 F150 10 07-12-2015 02:09 PM
big back window trim Smirks90 1957 - 1960 F100 & Larger F-Series Trucks 2 06-10-2015 01:02 AM
Rear window trim G_MAN Appearance & Dress-Up 3 01-22-2002 03:56 PM
Tags
2005, 9704, 99, back, butyl, f150, ford, glass, ranger, rear, removing, sliding, tape, trim, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
