removing trim around rear window? - Page 2 - Ford Truck Enthusiasts Forums
Old 11-10-2007, 01:29 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
in an earlier post is suggested sealing the trim to keep water out, and not pulling the window. After discussions with O2crew, i looked at the trim a little closer. I mistakenly though the trim was sealed to the glass panel, it is not. THe trim is only decorative. I had used sealer externally to keep the water from going under the trim. This workded in my case, but i think that depends on the location of the leak. ---- This morning i decided to dig a little deaper. Took the interior trim off the sides door post, and pulled the head liner and bottom trim out a couple inches. I could easily get to the 12 nuts holding the window in. removed the 12 nuts and started working the glass outward from the inside by prying a small screw driver easily around and around untill i had it worked out 1/4 inch. went on the outside and pulled the window out and set on tail gate. took 45 minutes to get to this point. took 45 minutes to clean off the old butyl seal off the windwo and truck lip. Ran to auto zone and got a 15 ft length of sealer for $8. THis looks like a 3/8 inch diameter black rubber (bytle) rope. You push it onto the window into the small track and it sticks good. put the joint at the bottom. set the window in the truck and push it in to seal. Go on the inside and tighten the 12 screws evenly starting at the top center and worknig outward. go around 3-4 times and pull in eavenly, tighten first at the top. Total it took about 2.5 hours. Works great if you clean up the surfaces and tighten in pattern. Looking at the photo above helped to understand how it is sealed. Mine did not leak after adding the external sealer, but the sure fix is to remove the window.
Old 11-10-2007, 08:26 PM
02crew's Avatar
02crew 02crew is offline
02crew is starting off with a positive reputation.
peace my ford drivin' brother. 02crew
Old 11-12-2007, 09:12 AM
JOE SKI JOE SKI is offline
JOE SKI is starting off with a positive reputation.
Why Can't You Just Mask It Off & Spray Paint It? It'll Take Time But A Lot Less Headaches
Old 11-12-2007, 10:19 AM
02crew's Avatar
i think the time spent masking, cleaning, you could remove it and be sure that it comes out mint, the way most of us would like it. has anyone painted theres yet?
Old 11-18-2007, 11:48 AM
How did you remove the vinyl trim framing the window in order to get at the nuts holding the window & trim pieces. I had a hard time getting in there with a small screwdriver to release the clips securing the pieces being careful not to break anything. I finally got one side off but what a pain. Is there a tool for removing these pieces?
Old 11-18-2007, 02:55 PM
steve(ill)'s Avatar
i took off the seat belt attachment bolt, pulled out trim below the window 2 inches--- i pryed out the post plastic at the top and pulled an onch and heard one pop. pulled to the top front and worked it out from the rubber door trim, just went down the back endge and "pulled" and it popped out. got ot pull pretty hard, but it did not break.
Old 11-21-2007, 08:03 PM
eazye187 eazye187 is offline
eazye187 is starting off with a positive reputation.
Quote:
Originally Posted by ncranchero
I'd get the parts listed at the bottom of this TSB if I were going to the trouble of removing/replacing my back glass.......
TSB # 01-1-11
http://www.ford-trucks.com/tsb/fullt...hp?tsb=01-1-11
Would any of this apply to a 2001 Supercrew? My rear window is leaking from the same spot mentioned in the TSB, almost directly behind the drivers head.
If not, should I just try to seal it, or pull both out and reseal completely?
Thanks,
Ernie
Old 11-21-2007, 09:44 PM
steve(ill)'s Avatar
fold down the back seat, take the 4 plastic round clips off the trim under the window and pull the trim forward 2 inches. --- take the seat belt attachment bolt off each door post--- pry out the plastic trim on the door post at the back windwo top edge and jerk it a little. it will pop out of the clips inside. work around the trim pulling it all the way off.---------- look above at the picture of the studs and nuts on the inside of the window. take off the 12 nuts from inside the truck---- pry the window out with a screw driver, slowly, easily along one edge, then all the way around. work it out 1/4 inch.----- go on the outside and pull the window off and set on the tail gate--- you can get a 15 ft roll of bytle sealing tape at Auto Zone for $8.--- clean off the old and install the new--- you will see where there is dust on the old seal where it leaked............... reinstall and snug the bolts in sequence.... dont flex the hood liner too far, just get your fingers above it to get the nuts on.
Old 11-21-2007, 09:47 PM
steve(ill)'s Avatar
there are two round clips on the head liner about 6 inches from the window. take them off, i forgot to say that--- dont flex the head liner too far.
Old 03-01-2009, 03:50 PM
racerx6466 racerx6466 is offline
racerx6466 is starting off with a positive reputation.
There's this stuff I use they sell at parts stores (I think mothers makes it) called Back to Black. It's made just for the sole purpose of resurrecting dead external plastic auto trim, and not just black trim. Works great. Unfortunately mine has a ring worn around it from a camper shell from the previous owner. Anyone know where to pick up a good one?
Old 12-31-2009, 07:56 PM
04 Lariat 04 Lariat is offline
04 Lariat is starting off with a positive reputation.
2004 F150 Rear Window Seal leak
I pulled out the window (there were 14 nuts that held it in) I bought the seal material at Autozone and reinstalled the window. All the info from you guys made this project a breeze.
Cheers and Happy New Year
Old 01-18-2010, 11:01 AM
dblake37's Avatar
dblake37 dblake37 is offline
dblake37 is starting off with a positive reputation.
I have taken out my rear window and it is obvious where the leak was because you could see dust where the black stuff should have been. Thank you to all AT FTE or the great info. Trying to do this blind would have added a full day of headaches. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Before I put everything back together I would like to find a new trim and rubber seal for the back window. The one I have is not only faded but has 2 broken clips where the studs are attached. Donít know if I broke them when removing or if they have been broken for a long time. The rubber seal which I understand is mainly just a diverter is dry and cracked.<o></o>
<o></o>
My question is where can I buy a new trim and seal for the back window.<o></o>
  #28
Old 01-21-2010, 12:29 AM
2004 f150 rear window
My sliding rear window may have been different than yours. I used the black butyl rope from Autozone. I think the studs on mine were part of the window. I didn't replace my outer seal. You probably would have to get the seal from the Dealer. The outer seal it pretty worthless as it doesn't mold to the body of the truck very well.
Good luck
  #29
Old 02-06-2010, 03:05 PM
schrocko-1999 schrocko-1999 is offline
schrocko-1999 is starting off with a positive reputation.
i accidentally destroyed the trim around my back window. anyone know where i can get a replacement?
  #30
Old 02-07-2010, 12:56 PM
richardfalco richardfalco is offline
richardfalco is starting off with a positive reputation.
Faded Trim
Straying a bit from the original post, but...
I use Penzoil Total Care to restore the black color of my faded trim. Seems to last the longest of all the 'restorative' products that I have tried. My truck sits outside a lot, and one application of this stuff lasts about 6 months for me.
RF
'99 F150 Rear Window Trim, where to find Moldylizard 1997 - 2003 F150 6 10-18-2015 07:13 PM
rear window chrome trim '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 0 08-09-2015 07:01 PM
Rear sliding window, remove? newfordy 2009 - 2014 F150 10 07-12-2015 02:09 PM
big back window trim Smirks90 1957 - 1960 F100 & Larger F-Series Trucks 2 06-10-2015 01:02 AM
Rear window trim G_MAN Appearance & Dress-Up 3 01-22-2002 03:56 PM
Tags
2005, 9704, 99, back, butyl, f150, ford, glass, ranger, rear, removing, sliding, tape, trim, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
