The unofficial Big Job thread.
#181
48 ford F6 - Holmes 515E
Here is the wrecker bed in it's current state. I have a second one for a parts doner and I am still missing a few nice to have items.
#182
Ford 429
I'd be quick to throw a 2nd return spring on that old throttle setup.
I've had a stuck throttle once, and know of one local hotrodder who went to the cruise in the sky due to a WOT tragedy. I recognize these ain't no hotrods, but another spring is some cheap insurance...
JML
JML
#183
the truck in my avatar is a photochop of someone else's truck.
i do plan to crew cab stretch mine, but my build will otherwise be much more "how would Henry do it". I have to fetch a donor frame as this one came with the original long gone and a late 90s bowtie 1 ton in its' place. That won't do. I hope to maximize my gvwr while remaining within the confines of the original sheetmetal dimensions (front axle width largely governing this selection process). I think I want Budd style wheels for minimized unsprung weight, and am shooting for a sub 26k gvwr.
here is my actual truck as it was drug into the shop:
JML
JML
#184
I guarantee to update. I think I might have already started a build thread here. Trouble is, I'm rehabbing an old house first.
I don't know how many times the wife has said something about how we can't live in the truck. I always reply with, "please don't tell me I can't do something. You don't know how that motivates me!"
#185
Anybody here good with electrical issues? I am plagued with a few gremlins on my truck. My charging system is not functioning properly. I installed all new gauges in the truck to include a volt meter. I also installed a duraspark2 ignition system. The entire truck has been wired from scratch, which has been a challenge due to conflicting information on how to wire some parts such as the duraspark module out here on the web. After trying different things, I am now to the point where everything seems to be working except the charging system. The truck does not have an indicator light for charging, so the "I" terminal on my voltage regulator is currently not connected to anything. (I mistakenly had it wired to the "I" terminal on my starter solenoid for a while.) After starting the truck, if I momentarily put 12V to the "I" terminal on the voltage regulator, the charging system works flawless until the truck is turned off and re started. Each time it is started, 12v must be applied to the "I" term of the voltage regulator momentarily for the charging system to function. If the "I" term remains connected to the ignition system, the truck will not shut off because this wire then feeds the coil with voltage. I'm confused. Any help would greatly be appreciated!
#189
Ok,
Its been a while since this got up near the top. I read the whole thread. I posted in another thread that I am on the fence about these Big Jobs specifically a 1956 ex fire truck. F800 has shortened frame rails (Shorter wheel base than when a fire truck)
Has around 20K miles has been stored for a while. Fire truck bed is long gone. I have not gone to look at it yet. So I really don't know the current condition.
I read some info here that the 56 is desirable. I did get some very good information on things to look for Like desirable wheel options.
I have too many toys now, but I have a problem! There I said it, and feel a little better too!
Just wanted to get any other opinions, ideas or suggestions, even price estimates or walk away issues.
Regards,
Chris
Regards,
Chris
#191
#192
Nice 54 Big Job! Bob, I zoomed in on the picture and I believe it is a MH All Wheel Drive.
Welcome to FTE, the best Ford Truck Forum on the World Wide Web! There are a lot of big truck guys here and MH guys here that can answer any questions you may have.
Thanks for the pictures. When you can show us more pics of the engine, interior and the MH parts and tell us about its history.
#194
