The unofficial Big Job thread.
#167
#168
on
56Ford 750
Thanks for the pic. I had a very similar setup. I wound up making a new linkage rod out of some 10 - 24 threaded rod. I could then tailor it in length to accommodate my new gas pedal. New pedal had a little higher pivot ball holder so I had to lengthen the rod so that the pedal linkage actually set lower in the cab.
#169
I see you are prior USAF. Same here - F4 and A-10 were my birds of the day. How's the 54 coming along? Made some progress on mine (56 F750) over the winter. Looking to find a cheep flat bed for it so I can drive it until I build / restore my Holmes 515 wrecker bed I intend to put on it. Truck is not all original and is intended to be a driver.
#174
#177
the truck in my avatar is a photochop of someone else's truck.
i do plan to crew cab stretch mine, but my build will otherwise be much more "how would Henry do it". I have to fetch a donor frame as this one came with the original long gone and a late 90s bowtie 1 ton in its' place. That won't do. I hope to maximize my gvwr while remaining within the confines of the original sheetmetal dimensions (front axle width largely governing this selection process). I think I want Budd style wheels for minimized unsprung weight, and am shooting for a sub 26k gvwr.
here is my actual truck as it was drug into the shop:
JML
JML
#179
That is a really nice looking truck! That will look great with the Holmes wrecker on the back. Do you have photos of the Holmes 515 you are going to restore?
#180
I'm leaning toward this one
this is along the lines of the original Holmes bed
Well, I did some photo shop work with one of my earlier pictures last fall and attempted to draw the concept bed onto my chassis. I am undecided between two shapes for the bed. See above. Anybody care to weigh in?
