generator to alternator conversion - Ford Truck Enthusiasts Forums
Old 10-24-2007, 07:42 PM
twise's Avatar
twise twise is offline
twise is starting off with a positive reputation.
I have a 292 Y block and was wondering what the correct steps are and any brackets that I made need to convert the generator over to a one wire alternator. thanks also does anyone know which belt would work for the alternator. thanks
Old 10-25-2007, 05:28 PM
twise's Avatar
anything? anybody?
Old 10-25-2007, 06:34 PM
Truxx1956's Avatar
Truxx1956 Truxx1956 is offline
Truxx1956 has a good reputation on FTE.Truxx1956 has a good reputation on FTE.
Talking
How handy are you? Can you weld? Those questions first, but what I usually do. I take the alt, and hold it up to the engine and start planing a bracket setup. Try to find a bolt hole you can use. I know th Yblock don't have any holes in the front of the heads. So most likely you'll have to come off from the exhaust manifold bolts, and the intake manifold bolts. I don't know if anyone makes a "bolt"on bracket that does that. I'm no Yblock guy, but there are several ones on here. Maybe they'll chime in here? Yblocks look really cool, and sound cool also, so good luck on finding a bracket setup. If you lived close to me, I'd come over and help you.
Old 10-25-2007, 06:54 PM
twise's Avatar
thanks for the info. i guess its just a matter of finding a good alternator and then just making a bracket to bolt it to so that it lines up with the pulley belt system, correct. i plan on buying a one wire alternator and then just trying to estimate which belt length i will need for it. thanks again.
Old 10-25-2007, 09:18 PM
itzaford itzaford is offline
itzaford is starting off with a positive reputation.
alternator
Well, on my Y block, I just reworked the existing gennie brackets, and used some heavy hardware store strap to make one of the brackets. I had a Delco alternator from the seventies that I used. I prefer the three wire setup. The parts are more available, and it should give you better performance. It is really easy to hook it up, with a little research. One heavy lead to the battery. The field lead goes to a light, then to the ign. switch. The sense lead goes to the heavy battery lead on the solenoid. There are some brackets available, but they seem pricey to me.
Old 10-26-2007, 06:41 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
Check out the link. This is how we did it.
http://www.ranchwagon.com/tech/alt/alt.htm
Old 10-26-2007, 06:43 AM
Walston's Avatar
Old 10-26-2007, 08:38 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Walston,I also used that one do-it-yourself plan from that ranchwagon site.It was easy,looks rather low-tech/stock,and is cheap.No elaborate fabrication necessary.There is a guy who occasionally sells a chrome bracket on EBay,for 119.00.Ouch!Steve.
Old 10-30-2007, 07:09 PM
Dave58 Dave58 is offline
Dave58 is starting off with a positive reputation.
I'm in the middle of the ranchwagon conversion. The bracket fabrication and mointing went pretty well. Doing the wiring now. The only problem, the previous owner had rewired the leads to the voltage regulator with wires the didn't match the color code of the original wiring and I'm not an electrician.
Old school generator looks with new tech jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-25-2013 01:26 PM
Generator to alternator conversion... California Codfish 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-04-2012 07:18 PM
1960 F-100 223 generator to alternator cal401 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-30-2011 01:04 AM
generator to alternator jozs56ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-08-2002 11:33 AM
64 F100 Generator to Alternator go_go_gadgit 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-23-1999 02:13 PM
Tags
1956, 1958, 1964, 292, alternator, block, convers, conversion, convert, f100, ford, generator, olders, wire, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
