Casting # year models ?
Originally Posted by 385seriesHemi
Yeah, I wouldnt see why not, Thats what the part numbers are pretty much for since they have the casting date in the part number themselves. Do you have a particular transmission number you are looking for and what engine is it used with?
No such thing. Casting numbers or specific casting dates do not translate to part numbers. Not now, not ever. Prior to 1953, Ford cast/stamped the actual part number on certain parts. But not since then.
There are casting dates on certain parts, but many numbers on parts are engineering numbers, not casting numbers.
If you find a casting number on a transmission, that usually only represents the specific part it's on..usually the case itself.
In order to ID a transmission, you need the Ford ID tag number from the trans. It's located on a metal tag either on the left side of the case near the levers, or bolted to the back side of the case.
60RatRod
08-14-2015 09:53 PM
pit_of_pity
04-14-2011 06:48 AM
MichaelMuck
09-16-2004 06:31 AM
chris eck
08-17-2004 10:12 PM
justmerod
04-10-2001 04:25 PM
