OK guy's I have a 2000 SD 4x4 with 3:73 gears, V10 motor. I'm pulling a 30' 5th wheel around 11,000#. Would you go with the 4:10 or 4:30. I also have a gear vendor (overdrive-underdrive). It's helps but needs a little more poop. Thanks
Can't speak from personal experience because I have a 3v, but a lot of the old timers say that if you're towing heavy there's very little mpg difference between the 4.10 and the 4.30, and they invariably recommend the 4.30 for the increased performance.
