Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-24-2007, 12:24 PM
BrianA's Avatar
BrianA BrianA is offline
Garage is empty, add now
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Rear Diff oil for 2005 F150
This is also posted in the Oil and Lube forum, but would like input from here as well.
Thanks in advance for any help.
2005 F150
Not LS rear end
I have to replace a leaking axle seal, so I get to open the diff and must therefore replace the fluid.
Ford calls for 75W-140 fully synthetic.
Local shop has one bottle, but several of same gear oil in Valvoline conventional (not synthetic)
QUESTION: Is synthetic necessary for my application or does Ford spec it because it could be considered "lifetime" and no drain/replace interval needed?
edit to add: I just looked back (online) at some mid-late 90's model F150 specs.
Those call for 80W90 conventional. I don't think the rear end has changed, so that really makes me wonder if the 75W-140 is required.
What should I do?
Go with the synthetic?
Use 75W-140 conventional?
Use 80W90 conventional?
Thanks!
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #2 (permalink)
Old 10-24-2007, 12:58 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Strictly speaking, 75w140 is not required, but it's a better oil; furthermore, if you have any warranty issues, 80w90 in there may be a sufficient reason to void the warranty on the rear.
The only scenario in which I'd use 80w90 if the axle were submerged frequently, necessitating frequent oil changes.
  #3 (permalink)
Old 10-24-2007, 01:01 PM
BrianA's Avatar
Thanks for the response, and hope for more.
For the record, it has 112,000 miles on it right now, so warranty is long since gone.
__________________
Brian A
  #4 (permalink)
Old 10-24-2007, 11:46 PM
In that case, there's no need for 75w140. My factory manual said not to mix synthetic and regular gear oil, so you want to drain as much as possible before putting in a different oil.
  #5 (permalink)
Old 10-25-2007, 04:57 AM
rsylvstr rsylvstr is offline
rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.
I'm using 75W-140 Amsoil and suggest it for your application also....since it's only 2 qts, it's about $15 and worth it.
__________________
Master Chief, HMCM(FMF/AW)
JOIN US http://www.nyfirearms.com/forums/ind...eferrerid=1780
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
Tags
2005, 75w140, conventional, diff, differencial, differential, differiental, f150, ford, gear, kind, oil, rear, tsb, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
