Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Kentucky Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: CampSpringsJohn
  #1 (permalink)
Old 10-24-2007, 05:04 AM
swarrenfamily's Avatar
swarrenfamily swarrenfamily is offline
Garage is empty, add now
swarrenfamily is new and has a neutral reputation at this point.
Exclamation Hey fellow ky GUYS & GALS
hey folks
i have a 2004 f-150 xlt supercrew 4 by 4 .all controls locks windows and mirrows quit! you can control locks on other (passenger side) door but windows wont work on any control. checked fuses ,relay,delayed accessory all ohmed ok.
pulled control panel in dr side and found no loose connections.i put a meter on wires to motor in door it reads voltage when you push the window up and down
as though the motor/regulator is bad but why is the other three windows out?and mirrows.are they wired in series ?
need help thanks! alex
  #2 (permalink)
Old 10-24-2007, 07:01 PM
kyredford kyredford is offline
kyredford is starting off with a positive reputation.
The best way to test the window motor is to hot wire it. What I mean is run a hot wire to the motor and ground the motor. If the motor works it is the switch if nothing happen it needs a motor or the window is off track and in a bind.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
