Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-23-2007, 09:05 PM
JFUSION is starting off with a positive reputation.
If Regulator is Bad Does Entire Alternator Need Replacing ?
I'm still trying to figure out if my alternator is bad. The battery voltage with the engine running isn't any higher than with the engine shut off. I checked all fuses and they seem fine. The alternator doesn't appear to be entirely dead, just providing lower voltage than what is spec'd with the engine running. The regulator may be the problem, just wondering if the entire alternator assembly must be replaced as a unit or if our regulators can be repaired seperately ?. Any info would be helpful, thanks.
Joey
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-23-2007, 10:28 PM
joes52f6's Avatar
joes52f6 is starting off with a positive reputation.
Usually you can get a regulator put in at a alternator rebuilder or probably any garage. Find an alternator rebuilder to test it first they should be able to tell you what's wrong. If yo take it to autozone or anywhere like that they will just tel you to replace it. Good luck JOE
__________________
"I Wanna Go Fast" Ricky Bobby
1952 Ford f-6 "Ethel The Capricorn"
1989 Toyota P/U "The Beater"
1969 Chevy C/10 "My Dad's, May he rest in peace"
  #3 (permalink)
Old 10-24-2007, 05:10 AM
sfcwoodret is starting off with a positive reputation.
May as well replace the Alternator because it's going to be bad within a year if it's output is already lower than required.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #4 (permalink)
Old 10-24-2007, 08:12 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman has a great reputation on FTE.NewEnglandHerdsman has a great reputation on FTE.NewEnglandHerdsman has a great reputation on FTE.NewEnglandHerdsman has a great reputation on FTE.NewEnglandHerdsman has a great reputation on FTE.
It used to be real easy to test the alternator when the voltage regulator was external, but it's not so easy any more. I'd take it to a shop that specializing in electrical components (i.e. rebuilds them) and have it tested. No reason to replace the whole thing if the only reason the output voltage is low is due to a bad regulator...
__________________
Jim
'06 F-350 5.4 4wd
'97 Ranger 4.0 4wd
'03 Escape Limited 4wd
'04 Mustang
'66 Hertz Shelby Mustang
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened." - Churchill
  #5 (permalink)
Old 10-24-2007, 05:57 PM
yeah the only reason I am thinking this way is because it's only got 42,000 miles on it (2 years old), I figure it should last longer than that, and it is likely the regulator that is keeping the output lower than it should be. I checked out the price of a Ford new regulator today, it actually isn't that expensive, I was surpised. But I'm wondering if I really should go back to one if the first one only lasted 42,000 miles.
Thanks for all of the replies.
  #6 (permalink)
Old 10-24-2007, 06:21 PM
SShank42's Avatar
SShank42 is starting off with a positive reputation.
Like others have said, take it and get it tested. They will run a couple of test on it. If it is not the reg. and something else they can determine that. That way if everything checks out ok then you know to let elsewhere.
  #7 (permalink)
Old 10-31-2007, 05:39 PM
turns out the alternator was dead. 06 Escape was 2,000 miles past warranty but the dealer is putting it through some warranty program that allows them to claim a major item that is just past the warranty limit. I don't know what that is called but apparently Ford allows the dealers to do that up to 2 times per customer if the dealer choses to do so. So they saved me a bundle. I have to pay $100 on the repair (almost like a deductible amount), full cost of the repair is over $500, so I'll gladly take that opportunity. The dealer says it is rare for a Ford alternator to fail at 42,000 miles, dunno if I believe them but I'll take the offer either way.
  #8 (permalink)
Old 10-31-2007, 07:10 PM
Beast12's Avatar
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Sounds like the dealer took care of you Joey. Kudos to them.
-Matt
__________________
-Matt (FTE Super Moderator)
2001 F-150 S/C XLT 4x4 Sport
Check Out The Ontario Chapter
"He who is tired of WEIRD AL is tired of life" -Homer Simpson
  #9 (permalink)
Old 10-31-2007, 07:44 PM
Quote:
-Matt
yes they certainly did , nothing but good remarks about them helping me out.
I appreciate the service coordinator going to bat for me through the service manager, all without me having to ask for it.
They said we can get some coverage on major items that fail between 60,000 and 80,000 kms, for 1-2 items max. . I decided to use one claim as I put on alot miles in a short period of time, I'll be at the 80,000 km mark fairly soon.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
