2001 Ford F-150 4.6; idle problem - Ford Truck Enthusiasts Forums
Old 10-23-2007, 08:34 PM
grant5127's Avatar
grant5127 grant5127 is offline
grant5127 is starting off with a positive reputation.
I'm having a strange problem with my 4.6 F-150. The idle is rough and has a rumble to it. The RPM's do not change while this occurs. I have tuned up the engine entirely, and ran a scan on the motor with a detailed program. It checked virtually every variable on the motor, and nothing turned up to be noticeably wrong. Above idle, throttle response is fine and there are no mis-fires. A friend of mine suggested that it may be the ethanol 87 gas, so I ran down the tank and put in 93. This gave me no noticeable change. Can anyone provide some insight?
<!-- / message --><!-- sig -->
Old 10-24-2007, 12:40 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
When you turn the ignition on, does the CEL illuminate and go off? Is the CEL on when the truck is started. I assume that the scan that you ran checked the truck for stored trouble codes. Good luck!
Stalling yasky69 2004 - 2008 F150 7 08-02-2016 11:19 PM
2003 4.6 rough idle mainefordman 1997 - 2003 F150 10 07-11-2015 09:39 AM
idle rises slightly while pumping brake, (HELP) mark1963 Modular V8 (4.6L, 5.4L) 1 05-29-2015 09:22 PM
swap tsmithstur 1997 - 2003 F150 0 03-22-2015 10:32 PM
4.6 motor differences Crabby144 1997 - 2003 F150 12 08-29-2014 01:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
