10-24-2007, 08:04 PM
with 4.10 gears 3000 RPM will put you at 70 MPH.
The redline on the diesel is 3300 and operating at RPM that high will suck down the fuel.
Burnouts with a 7000 pound truck can get expensive, driveshafts and U joints do break.
Loud is no problem, remove the mufflers and you will have to roll up the windows to hear the radio.
Blowing black smoke is easy to do, but with fuel prices it can get expensive as well.
The transmission should be a C 6, non overdrive but a tough transmission.
Should be an excellent plow truck if everything is in good shape.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
