Taking Parts of a Flathead - Ford Truck Enthusiasts Forums
Old 10-23-2007, 07:37 AM
rcav8or's Avatar
rcav8or rcav8or is offline
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
Hi, all...
My '51 F2 Flathead was missing some parts, manifolds, cleaner, etc.
I am going down tomorrow to Kentucky to pick apart a flathead, with a rod through the pan. I can take everything I can get off the motor.
I will have about 6 hours get everything I can off the motor. I have never torn one down. The motor is still in the truck, and I will not be pulling it out. I need some suggestions...
What all should I take? I will take the obvious - head, genny, all the outside stuff I can get off, manifolds, distrbutor, etc.
Should I try to remove the valves/springs/lifters/etc? How hard can they be? I read up on how to remove them, and have the tools, but is it worth it? Whatever I don't need on mine, will be cataloged and stocked as spares.
I may be able to lift the block off the front mounts - should I take the pumps? Front cover? gears behind the cover?\
Any secrets to taking off the front pulleys?
Anything I've forgotten?
How long should it realistically take?
I really want to get all I can, as an opportunity like this doesn't present itself every day.
Thanks in advance, for any help/suggestions/hints/comments you can give me. As I said, I am leaving here at 4:00 am tomorrow morning, so time is of the essence...
R
It's time to show you guys what Ross and Ray did for me--Engine Swap Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 12-17-2013 04:43 PM
52 f3. Kanepfc 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-23-2013 07:16 PM
Flathead cleanup Stickid Manitoba / Saskatchewan Chapter 15 02-07-2010 10:46 PM
Transporting a flathead motor rcav8or 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-25-2007 06:57 PM
Flathead Help. restoringmy46 Flathead V8 & Flathead 6 4 03-13-2006 06:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
flat, ford, head, indiana, parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
