Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-23-2007, 03:11 AM
f250 beast's Avatar
f250 beast f250 beast is offline
Garage is empty, add now
f250 beast is starting off with a positive reputation.
Question some propane questions
k well i got a few questions regarding my set up in my truck. its a 302 that only runs on propane, it has a impco model e vaporizer and impco 300a mixer. k well the vacuum line going from the intake manifold to the vaporizer about half way to the vaporizer it has a adapter for another line to go to it, i danno what line goes to it, or if it was just put there to make the line longer??? and another thing on my mixer i have a short line hooked up to it witch has also been blocked off.
i have asked people on the propane forums about this and non of them have any idea to what these lines should be doing because there not to familiar with this set up, but yeah the truck is a 88 F250 with a 302
if any of you have a similar set up your help would be much apreciated. currently the truck runs fine but i have always been wondering about these mystery lines
  #2 (permalink)
Old 10-24-2007, 03:27 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Normally a CA300 mixer does not have any vac lines connected to it. The only exception would be a balance line. If it has a VFF30 Vac lockoff (fuel shutoff) It will have a line for mainifold vac to it. The model E may have a black solenoid screwed into the side of it with a vac line going to manifold vac, that is a start assist (primer/cold start) that uses manifold vac to open the regulator quicker in the start position only.
What kind of problems are you having?
Btw that set-up can be converted to dual fuel fairly easily if the gasoline system is intact
Regards
Gasman
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #3 (permalink)
Old 10-24-2007, 07:34 PM
f250 beast's Avatar
k but the vacume line going to the vaporizer, for the cold start prime, there is a fork in the line, witch i capped off, i was just wondering if it has to be connected to another vacuum source and on the bottem of the mixer it has a line that has been capped off too, i am just curious to were they go, it so far runs fine but when its cold it has a hard time to start up
  #4 (permalink)
Old 10-25-2007, 07:11 AM
gasman6674's Avatar
1996 Ford F-350
Pull the line off of the mixer it does not need to be there.
The SV (start assist) should be screwed into a port on the side of the vapoizer that is below the level of the diaphragm. It should be connected to mainifold vacumn and a 12 volt source that is only hot while cranking. You also need to make sure that the vacumn fuel lock is hooked up to manifold also. If your engine has low cranking vacumn it will be harder to start cold.
__________________
Jim England
Tags
ca300, diaphragm, held, impco, line, mixer, model, nca300, runs, series, vacuum, withprimer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
