Quote:
Got it on ebay, E350 with a hypermax turbo, it had a high mileage engine with oil in the coolant.
Probably just the Orings in the oil cooler were cracked and leaking....
Pickup change may solve it .....also try wiggling all the connectors on the back of the cluster. Do one thing first then if no good results do the other.... Get the new pickup with the plastic covering......the old one's had metal showing and filings would stick to it and screw it up. Check wires for breaks too.
Water in fuel light problem could be a worn shorting out wire........
