Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-22-2007, 11:39 PM
ghunt's Avatar
ghunt is starting off with a positive reputation.
How long of an extension cord can a block heater be run off of?
I'm pretty close to buying a truck, it has a block heater which I would obviously like to use this winter. However, with how my apartment is, it will require about a 50 foot extension cord to get power to it. Will that be a problem?
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
http://www.cardomain.com/ride/306349
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-22-2007, 11:49 PM
guthrie&co is gaining momentum as a positive member of FTE.
as long as the cord is big enough to handle it. just get a cord that has the larger guage wire in it. i am sure someone else will chime in and tell you what size to buy.
__________________
These messages are brought to you by the number eleventy seven & Shirley Q Liquor
  #3 (permalink)
Old 10-23-2007, 12:06 AM
ghunt's Avatar
Well I was looking at the bigger gauge cords, I plan to get a decent one of course.
__________________
  #4 (permalink)
Old 10-23-2007, 12:10 AM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
Yep, get a heavy duty cord. I've ran my chord(s) for close to 100 feet before. Just make sure you have good connections. I'd get a 12/3 or maybe a 10/3 cord.
If you use too small of a gauge it will melt the plugs or the cord will get hot.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / 6637 / CCV / 203 Stat
  #5 (permalink)
Old 10-23-2007, 12:12 AM
brmpipes is starting off with a positive reputation.
I run a 100 foot cord for my truck and it starts no problem in the winter.Here in alberta it is not uncommon to get to -35 to -40 c.
  #6 (permalink)
Old 10-23-2007, 01:01 AM
afreemanmd is starting off with a positive reputation.
how many amps does a block heater really pull? anybody measured it?
  #7 (permalink)
Old 10-23-2007, 05:41 AM
killaford is starting off with a positive reputation.
i think it was was 800 and some clamped.
__________________
'07 4x4 F350 SRW SC short bed, Lariet-silver metalic, 6.0 Powerstroke Diesel - auto trans, chrome pkg, snowplow prep pkg, camper pkg, skid plates, tow command, roof clearance lights, fumoto valve, HFCM upgraded drain plug, 24 x10 Incubus Brawn 8 rims, 305/40-24 General Grabbers
  #8 (permalink)
Old 10-23-2007, 05:53 AM
alchymist's Avatar
alchymist has a good reputation on FTE.alchymist has a good reputation on FTE.alchymist has a good reputation on FTE.
Quote:
Usually rated in watts, and most fall in the 200- 500 watt range. A 1000 watt heater is at the high end. So, for a 50 foot run, a #14 three wire cord would suffice. At the high end, 1000 watts, still only pulling 9 amps, so it's still ok. Now, with that said, you're probably not gonna use it only for the block heater, so for all around use get one size heavier, ie, #12. The 12 gauge 3 wire 50 footer is a good all around size. And for peace of mind, get a ground fault adapter - ...
http://www.ohiopowertool.com/item-detail.cfm?&ID=A1402-003-GFCI
fficeffice" /> > >
http://www.lowes.com/lowes/lkn?action=productDetail&productId=145277-33536-30338062&lpage=none
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab 4X4 V10
07 Gulfstream Prarie Schooner
'05 Escape
'04 Focus
Passed the exam today! I am now a licensed instigator!
  #9 (permalink)
Old 10-23-2007, 08:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
Ford's block heaters are 1000 watts. Aftermarket heaters may vary.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #10 (permalink)
Old 10-23-2007, 09:02 PM
texastech_diesel's Avatar
texastech_diesel is gaining momentum as a positive member of FTE.
A does a normal orange utility cord work? In a normal GFCI outlet?
__________________
Bryan
  #11 (permalink)
Old 10-23-2007, 09:23 PM
F350-6's Avatar
Slow Typing
F350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to behold
Quote:
Color won't tell you much, but typically the cheap extension cords you see at the local Home Depot/Lowes are 14/3. That means they're running 14 ga. wire. You can usually find a good deal on a 12/3 (12 ga. is heavier than 14 ga.) 50 foot cord but a 12/3 100' will start to get pricey. The 10/3 cords you will have to pay for.
  #12 (permalink)
Old 10-23-2007, 09:29 PM
alchymist's Avatar
Quote:
And if you think the 12/3 gets pricey, try the 4 wire 50 amp cable for the RV - 18 feet with plug & twistlock conector will set you back $150.00.
__________________
'05 Escape
'04 Focus
  #13 (permalink)
Old 10-23-2007, 09:42 PM
F350-6's Avatar
Slow Typing
Quote:
If you get over 10 gauge it's cheaper to make your own cords. Find an electrical supply house and buy the wire by the foot, along with the plugs you need.
  #14 (permalink)
Old 10-23-2007, 10:33 PM
medhvac's Avatar
Its not pollution Its HP!
medhvac has a good reputation on FTE.medhvac has a good reputation on FTE.
i use a 100 ft , but why plug the truck in if you dont have too!
__________________
early 99 f-350 4x4 crew cab xlt 7.3 4" mbrp DP
GREG
2001 ford mustang (no cats)i co-signed for my son so its half mine and when hes gone to IRAQ guess who get to drive it!(the wife)
As of 5/12/08 He`s in Irag where abouts unknown
  #15 (permalink)
Old 10-24-2007, 03:19 AM
mnmwhit is starting off with a positive reputation.
You are getting some good info and some bad info. I can tell you that the Ford Block heaters are not 1000 watts as someone else stated earlier. They are usually 200 each. you may be able to find out from your dealer. And then find out if you have one on each side or do you just have one heater.
If they were 1000 watts I would have a BIG problem. Because I have two (one one each side of my engine, I have a 125 watt heater under each battery, an 800 watt interior heater, a 100 watt oil pan heater and a 100 watt transmission heater.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
