Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-22-2007, 06:16 PM
72soa 72soa is offline
Garage is empty, add now
72soa is starting off with a positive reputation.
blown fuse
We have a 2007 expedition el. I got the tow package because I tow with it. I have three trailers that I tow with the truck. The small trailer and boat trailer use a 4 pin plug. My tandem axle trailer I use to haul my IH scout 4x4 uses a 7 pin trailer. I noticed my lights were not working on the big trailer and I was not getting power to the turn signals and brake lights on the 7 pin plug on the truck. I get power for running lights. In any event I look at the fuses and find a blown 25 amp fuse that controls the turn/brake lights on the 7 pin plug. I am going to replace the fuse and see what happens but any ideas on what could cause the fuse to blow would help a lot. Do you all think I have a problem with the trailer wiring? If so is it a ground problem. I need some help. BTW I do not have a brake controller yet hooked up.
  #2 (permalink)
Old 10-22-2007, 09:44 PM
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
I would start with the trailer wiring. You can check your ground on the ball as-well. You may need to grease it depending on your trailer. I would also take a look at the plug on the truck and make sure that all of the wires are secure into the back. If you are looking for a good controller I just bought a Tekonsha P3 and it works like a champ.
__________________
'08 F250 KR 4X4 Diesel CC Dark Blue
'07 F-150 SuperCrew Lariat 4x4 Dark Stone
  #3 (permalink)
Old 10-23-2007, 04:23 PM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
Assuming you have the heavy duty tow package, the trailer plug wiring has its own isolated relay isolated circuit and fuse protection. This is a very nice feature as you just found out that you only blew a fuse on the the trailer lights and didn't loose all your turn signals on your vehicle. Look at the wiring diagram that is with your brake wring pig-tail (check by your tire tools & jack) for the relay & fuse info. You should not rely on the trailer ball for a ground. Use a multimeter to check for shorts to ground on the trailer wiring.
Tags
2006, blown, blows, diesel, f150, f250, ford, fuse, fuses, lights, navigator, problem, tow, trailer, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
