1994 "codes" - Ford Truck Enthusiasts Forums
1994 "codes"
Old 10-22-2007, 05:58 PM
shorthair shorthair is offline
shorthair is starting off with a positive reputation.
1994 "codes"
My wife's explorer has a hesitation when accelerating also running rough at all speeds . code #'s 157, 167, 159,173, 137, 536, 538. I have cleaned the mass air flow sensor 3 times this week & it still doesn't run any better help .
thanks in advance
Old 10-22-2007, 07:05 PM
also checked voltage on the mass air flow & got a&b 14.26 and c&d .68 running
Old 10-22-2007, 11:42 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
When resolving a list of EEC-IV codes, you start with the KOEO codes (1st set output during the KOEO test before the separator pulse/code 10). You didn't specify which codes were which, but I looked up those codes, and the only likely KOEO code I see is the 159. Was the 159 a KOEO code or a KOER code?
I'll also note that KOER 167, 536 and 538 are almost always operator error. They are usually from neglecting to press the brake immediately after engine id and neglecting the "goose" test.
Remember that trouble codes only point to problems in circuits, not just sensors. A break in the wiring between the MAF and the PCM (or other sensor and the PCM) could easily be the cause of the codes.
Mass Air Flow Sensor gone bad? zapola6 Modular V10 (6.8l) 10 10-11-2015 08:54 AM
1977 F250 4X4 lute Vehicles for Sale 7 06-27-2014 03:14 PM
x codes and 35" tires??? Picts?? Bowie 1999 - 2003 7.3L Power Stroke Diesel 3 03-29-2011 03:15 PM
Pro Comp 2" leveling kit on an F350 psd76 1999 - 2003 7.3L Power Stroke Diesel 7 01-04-2011 06:39 PM
Axle Code "35" = ? go2toa 1987 - 1996 F150 & Larger F-Series Trucks 18 11-24-2005 05:46 PM
Tags
137, 157, 1994, 536, 538, code, eec, explorer, ford, iv, koeo, koer, limited, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
