Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2007, 03:30 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
1969 Ford Cummins Crew Cab Conversion
Hey Guys,
Thought that I would share my current project with you all. I'l post pics and bring the thread up to current as time permits... Her are some early photos from July 3, 2007.
  #2 (permalink)
Old 10-22-2007, 03:33 PM
HRDROKN's Avatar
Found a lot more rust then what was disclosed by the previous owner! In fact he described the truck as being rust free...
  #3 (permalink)
Old 10-22-2007, 03:37 PM
HRDROKN's Avatar
Plan is to cut out all (or most) of the rusted section and weld in new metal.
I'll post some more later tonight....
  #4 (permalink)
Old 10-24-2007, 11:52 AM
HRDROKN's Avatar
Previous owner did a real hack job on this frame! I have already developed a plan to repair it....
  #5 (permalink)
Old 10-24-2007, 11:56 AM
HRDROKN's Avatar
Cummins goes in for it's first test fit....
  #6 (permalink)
Old 10-24-2007, 12:03 PM
HRDROKN's Avatar
After some carefull measurements, I decided to build a new cross member and relocate it rearward of the stock cross member. This will enable me to retain the stock Dodge/Cummins A/C compressor location. The motor will be set 2" offset to the passenger side. Pics....
  #7 (permalink)
Old 10-26-2007, 11:00 AM
HRDROKN's Avatar
Fabing passenger side motor mounts.... motor will be set at 2" offset.
  #8 (permalink)
Old 10-26-2007, 11:12 AM
HRDROKN's Avatar
Drivers side motor mount...
  #9 (permalink)
Old 10-26-2007, 11:22 AM
HRDROKN's Avatar
Mounts completed....
  #10 (permalink)
Old 10-26-2007, 12:13 PM
loudfords's Avatar
loudfords loudfords is offline
loudfords is gaining momentum as a positive member of FTE. loudfords is gaining momentum as a positive member of FTE.
Awesome. Keep it up!
__________________
Chad - loudfords
1979 F150 351W
2001 Focus
Ford LT75 lawn tractor
  #11 (permalink)
Old 10-26-2007, 02:45 PM
jrzoffroad jrzoffroad is offline
jrzoffroad is starting off with a positive reputation.
Great swap, everyone wants to see the conclusion!
Keep up the intensity.
__________________
Jerry
67 F100 2wd, SWB 460
67 F250 Crew Cab 4x4
72 F100 4x4 SWB
72 F350 2wd Crew Cab
  #12 (permalink)
Old 10-26-2007, 04:06 PM
jonbass40 jonbass40 is offline
jonbass40 is starting off with a positive reputation.
Nice fabrication You should put up the mesurments up so if anyone else is intrested in this. Awsome job.
  #13 (permalink)
Old 10-26-2007, 06:20 PM
HRDROKN's Avatar
Quote:
I was keeping pretty good track of all the measurements as I was thinking that someone might be interested... of course looking back through my notes and drawings, it looks like I forgot a few pieces
I was thinking that it would be a good idea to make a jig for this swap?
  #14 (permalink)
Old 10-26-2007, 07:07 PM
nevrenufhp nevrenufhp is offline
nevrenufhp is starting off with a positive reputation.
There is definite interest by lots of people for a Cummins B swap into a Bumpside. That truck is even cool without an engine.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
Got a 4BT to swap in it.
  #15 (permalink)
Old 10-27-2007, 12:33 AM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
1953 Ford F-750
wmjoe1953 is gaining momentum as a positive member of FTE.
Any data you can provide is great. We have many interested in the same swap over in the 48-60 section.
__________________
Check out my gallery
If Ford trucks are an addiction, then this must be the support group.
More pics of the Big Job can be seen here:
http://s248.photobucket.com/albums/g.../1954%20F-800/
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
