I have a dumb question. Is there anything that would prevent the pocket bearing from working its way further into the pocket and off the end of the Ford shaft? Odds are slim it would happen, but knowing how things go for me...
BTW: Really nice post!
Interesting point! There is no thrust load on that bearing so hopefully it stays put, but since it is already assembled... I think I will look at throwing a spacer in the input before the NV4500 output goes in. I think the better way would have been to shim between the end of the splines to back of the bearing pocket in the first place.
Finished doing the fixed yoke conversion on the Dodge NV271. Just waiting for new input/output seals to get here....
Re-drilled the NV4500 tail housing to rotate the transfercase for an improved front drive shaft angle. I used a advanced adapter pacer as a drill guide...
This is a Eaton BB type power steering unit... I was able to order a seal kit and new regulator valve to reduce the op pressure to 1500 psi. I talked with the guys over at PSC and they said 1600 psi to my steering box (78-79 Ford) max or the sector shaft seals will leak, so thats why I went with the 1500psi reg.
Quote:
Originally Posted by HRDROKN
I came accross this power steering pump that was amongst a bunch of 96 motor parts that I purchased off craiglists....
Well it seems that I'm having a bit of trouble trying to find what application these were used and even unsure if it was even a Dodge option for 1996.
I want to use this pump on my 69 Ford Crew Cab project that I'm currently setting up for hydroboost... does anyone have any info on exactly what application this pump originates?
Drive haft will be here next week.... these guys over at High Angle Driveline have taken that agricultural CV (which does not survive sustained high speed applications) and performed (what Jess describes as) a little (or was it major) brain surgery. The net result is improved lubrication and durability for street use!
Here she is next to your standard 1 ton 1350 series CV...
all I have heard from on it is a bunch of true believers that cannot explain why they believe what they believe, but they just believe it. I save that for my belief in Christ Jesus, but when it comes to Ford trucks, I wanna know why something is the way it is.
Finally getting back to getting this 4-link built. There is a slight tweak in this frame under the drivers side... that shows up whenever I'm trying to establish reference points for measurement.
Damn that is going to be a monster truck?
__________________ ================================================== More to come....
I was just looking back on this thread, and the rear brake conversion on this caught my eye. Those caliper brakets that you have, are those the same as the ones for the D60 or are they specific for the D80? Also what are use useing for pads, rotors and calipers? Awesome looking build though. I cannot wait to see what it looks like when it is totally finished.
I bought a conversion kit from Blackbirds Custom Trucks... I remember that they had to re-cut the plates for me, the index ID or bolt circle was off. I don't know the specifics of the calipers... sure that they are some standard GM stuff.
1960's Volvo motor mounts work nice for the trans....
Ok, been following this thread for a while now and you're rockin this thing. I'm like everyone else and waiting till this thing is completed just to see the final product.
Question on the rubber issolator mounts: How thick are they and what sized studs? Are the studs on both sides? What's they cost and where can I get some?
Thanks and again - GREAT WORK!!!
__________________ Ryan
95 F350 CC Dually psd auto; Some work is being done on it but the sig police won't let me list it out
Pics to come!!!
Hey,what is the hydroboost assy from? I have a 5.9 going in my 64 and it has that nice hydraullic pump on it and am thinking about doing hydroboost and a toyota steering box to get power steering.
Thanks
__________________
1964 f250 2wd with a 97 cummins and allison at545
1966 mustang "a" code true GT t10 4speed
1967 cyclone "s" code true GT top loader 4speed
1923 model "T" speedster 20hp of spinnin fury!
1989 dodge d250 360efi auto
(dad bought it new,I remember riding home in it)
I just read through every page of this build... It is completely awesome.
I'v wanted to do this for a couple years now. Im glad that its coming together so nicely, slowly, but nicely. And its gonna make one heck of a truck, not only an awesome truck but a reliable, well built one.
