Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #121 (permalink)
Old 08-28-2008, 02:16 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
So all is not so simple...
I'm trying to determine if my front output yoke will clear this area without modification. As it is the trans needs to come down by about 1.000" so that the top of the TC clears the cab floor support beam or clearance the beam would be the other option. If I lower the trans, then I will have to lower the x-member or re-fabricate for front yoke clearance.
I'll get back to it in the morning....
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #122 (permalink)
Old 08-28-2008, 08:07 PM
HRDROKN's Avatar
Looking at the x-member it looks like if I weld in a half round and rotate the NP205 clockwise (from the rear) I might just get the CV joint to clear.
Hmmmm.... off to fabricating I go! Heck if it doesn't look good I'll scrap it... Start over with some boxed tubing!
Stock mounting location....
Rotated location.....
It's all fun and games when you work with cardboard!
__________________
HRDROKN
  #123 (permalink)
Old 08-28-2008, 11:08 PM
Bill W's Avatar
Bill W Bill W is offline
<<< under construction
1966 Ford F-100
My Garage
Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of
Great build! i cant belive Garbz has not posted to this one!
__________________
My Truck- Here!
Join AZ Chapter Here!
  #124 (permalink)
Old 08-30-2008, 04:32 PM
HRDROKN's Avatar
So it all starts as a simple output seal replacement... then you find a suspect bearing... then you start looking at the cost of seals and a single bearing vs a complete rebuild kit and this is how the day ends...
__________________
HRDROKN
  #125 (permalink)
Old 09-02-2008, 04:08 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
It's a - it's a - it's a NP205! I recognize those parts
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #126 (permalink)
Old 09-03-2008, 11:00 PM
dodmort's Avatar
dodmort dodmort is offline
dodmort is starting off with a positive reputation.
sooo
my stupid ? of the week
show me why it is not a np200....
is it the bearings or just no one would use a 200 if they were in their right mind..
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Guns, Guns, Guns......."Clarence Boddicker" Robocop circa 1987
  #127 (permalink)
Old 09-04-2008, 04:48 PM
HRDROKN's Avatar
OK.... so I get the Advanced Adapter kit to mate a 29 spline male output ( Dodge NV4500 5spd) to a 31 spline female Ford (NP205) input shaft. And I must say that it didn't give me that warm fuzzy feeling that the AA spud shaft wouldnt be the weak link! It was thinest at the taper due to being square bored in the internal spline.
So I started looking at options again.... I decided that I really like the thought of using the Dodge NP205 29 spline input, so I called AA to see if they had any thicker spacer rings then the 1.600" that comes with the kit? Nope! But they are sending me another spacer ring in return for the kit supplied spud shaft. So I will mate the two spacer rings, use the 29 spline NP205 input shaft and a stock Dodge 29 spline coupler.
Dodge 29 spline....
Ford 31 spline....
I was going to have to replace the Ford input anyway.... to much rust for me!
__________________
HRDROKN
  #128 (permalink)
Old 09-04-2008, 04:49 PM
HRDROKN's Avatar
Quote:
Ya.... I can't believe it either!
__________________
HRDROKN
  #129 (permalink)
Old 09-09-2008, 12:18 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Just subscribing to this. I have been watching over on the Cummins forum and didn't know you had a thread here until I cam to post mine!!!
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #130 (permalink)
Old 09-13-2008, 12:00 AM
Steilenberg's Avatar
Steilenberg Steilenberg is offline
Steilenberg is starting off with a positive reputation.
Looks great, check out my 68 F600 12vCummins
  #131 (permalink)
Old 09-18-2008, 12:09 AM
HRDROKN's Avatar
Quote:
Originally Posted by dodmort View Post
sooo
You know.... I don't think I have ever actually seen a NP200? Heard of them, but never looked into them.... Is it a single speed 205?
__________________
HRDROKN
  #132 (permalink)
Old 09-18-2008, 12:11 AM
HRDROKN's Avatar
Well, I'm waiting for some TC parts from JB Conversions that were being held up by hurricane Ike... so I started stripping the interior so I can take it down next Monday (22nd) to get spray lined. Then I will have the front and rear glass re-installed. I will then be able to start re-wiring the truck, as well as assembling misc. other functions, like steering and brakes.
__________________
HRDROKN
  #133 (permalink)
Old 09-18-2008, 12:17 AM
HRDROKN's Avatar
So as far as the interior plan goes...
Welding interior seams, grinding and sealing.
The majority of the interior will be spray lined, mostly for the sound deadening effects. Still going to have carpet, headliner, ect.
Will fab aluminum gauge panel insert for a full compliment of mechanical gauges. All switched functions will be via toggle and relay circuits.
Wiring harness from EZ-wire.
Seats are undecided at this moment. Might have to go with the standard milk crate till I get a plan!
Thats about it for now....
When I get the truck back from Line-X, I'll continue the NP205 install with the Dodge input shaft.
__________________
HRDROKN
  #134 (permalink)
Old 09-18-2008, 04:18 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
Quote:
thats gana look interesting untill you get the carpet and headliner in... will the side of the cab be spray lined? or jsut the top and bottom?
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #135 (permalink)
Old 09-18-2008, 07:14 PM
1974 Ford F-250
I plan on doing both the inside and underside of mine. Up the firewall on both sides, and probabyl up the back wall on both sides. Still deciding where to "cut" it along the side - but I most likely won't go up the B-pillars at all.
You thinking kind of the same thing - or less spray?
__________________
1970 Ford F250
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
