Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #106 (permalink)
Old 08-14-2008, 10:33 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
Advance adapters makes a kit. Its $425. I thought about it for my conversion but im just gona use the dodge 205 with another short d shaft and then a divorced ford 205. Not only can i then use the ford front but i have a doubler too.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #107 (permalink)
Old 08-15-2008, 10:29 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
One thing is that I would not use cross-drilled rotors. They have a nasty tendency to crack. Not trying to knock you, just trying to look out for your safety. If you want some kind of performance rotors, go with slotted.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #108 (permalink)
Old 08-16-2008, 03:01 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Quote:
Too late....
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #109 (permalink)
Old 08-16-2008, 10:52 AM
HRDROKN's Avatar
Quote:
Ya.... I could go that route, but if I can swaps some parts around and save the cash, then I'll have to give it a shot!
__________________
HRDROKN
  #110 (permalink)
Old 08-17-2008, 01:14 PM
HRDROKN's Avatar
Well while I'm waiting for some parts again... I had an opportunity to get back to the drivers side floor pan!
__________________
HRDROKN
  #111 (permalink)
Old 08-17-2008, 05:22 PM
80F100man 80F100man is offline
80F100man is starting off with a positive reputation.
Looks good mate, wish I could weld like that
__________________
Life is what you make it, so make it good for yourself .
  #112 (permalink)
Old 08-17-2008, 07:03 PM
John_deere_kid's Avatar
John_deere_kid John_deere_kid is offline
John_deere_kid is starting off with a positive reputation.
Quote:
Your not the only one. That does look REALLY good
__________________
BLUE THUNDER
1993 F150 Flareside
5.8 351w (used to be 5.0 302)
Automatic
4x4
130,000 miles
  #113 (permalink)
Old 08-25-2008, 04:30 PM
HRDROKN's Avatar
I have all the necessary pieces to get that NV4500 in place (working it almost as we speak) and then going to get the motor ready to fire... which includes the KDP fix and other misc. items. If she sounds good then I'll continue getting the driveline in place.
Also finishing up some body panel welds this week....
I'll have some pics by weeks end!
__________________
HRDROKN
  #114 (permalink)
Old 08-25-2008, 05:33 PM
I saw you mention something about the KDP fix over at CumminsForum. Good thing your taking care of it now before it decides to drop into your gear train.
__________________
- Ian
  #115 (permalink)
Old 08-25-2008, 05:55 PM
andym's Avatar
andym andym is offline
1989 Ford F-150
My Garage
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
Quote:
Better than factory.
Man, that truck is sweet. I'm just up the road from you, and I frequent the pick-n-pull in Rocklin. Let me know if you need me to keep an eye out for parts. I'd be proud to tell people I had a small hand in helping you with that beast!
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #116 (permalink)
Old 08-26-2008, 09:43 AM
HRDROKN's Avatar
Hey Andy,
Next time you are out, if you would.... keep an eye out for fenders, preferably a pair, but at a minimum I need a passenger side!
Thanks!
Mark
__________________
HRDROKN
  #117 (permalink)
Old 08-26-2008, 10:27 AM
HRDROKN's Avatar
Yes... my luck it is just hanging there ready to fall out when I test fire the motor!
__________________
HRDROKN
  #118 (permalink)
Old 08-28-2008, 01:35 AM
HRDROKN's Avatar
Alright....
Finished the front driver side cab mount. So that's enough body work for now!
__________________
HRDROKN
  #119 (permalink)
Old 08-28-2008, 01:45 AM
HRDROKN's Avatar
I wanted to update the tie rod issue with heim joints.... since sheer is a big concern I'm going to use full shank grade 8 bolts and just cut off the un-used portion of threads! I'm going to add a spacer (.062) under the heim for a little more clearance. The body of the heim can not pass the bolt head... so no washer.
__________________
HRDROKN
  #120 (permalink)
Old 08-28-2008, 01:50 AM
HRDROKN's Avatar
So where are we....
Oh ya..... getting that nv4500 in place. The trans fits real nice!
Looks like I'll be able to make use of the stock cross member!
__________________
HRDROKN
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
