I'm actually a Union Millwright working in a fab shop and your fab skills are top notch, looks just as good if not better than the work I see Journeymen doing on a daily basis in a shop with access to any and all available tools and equipment.
H, this is some fantastic work. With the level of craftsmanship on this and other projects on fte, I am humbled and inspired.
And if/when you put this truck up for sale, please let us know. I know I might be tempted. Just make sure the cab's comfortable, because that's where I'll probably be sleeping after the wife finds out
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
Just attempted to swing my NV4500 into place so that I could get to fabricating the new cross member, but it didn't go! It appears that the input shaft is bottoming out on the end of the crank. Taking a measurement showed that the Input shaft is aproximately .750" too long. Input shaft total length is 7.750" and the bellhousing depth to crank end (no pilot bearing) is 7.000" .
My only guess at this point (and My question) is that the bellhousing adapters are different between automatics and manuals??? Or is it that my adapter being a 1993 is too shallow??? Are 1994 and up deeper???
Looks like my adapter is about 1.250" deep... if that helps.
Found a 03 - 06 adapter and it looks to be the propper depth, but not sure if it will cause other problems!
UPDATE: It looks like I'm in the market for a 94 - 02 bellhousing adapter from a 5spd (NV4500) truck.
So on to other stuff then....... while I look for a new bellhousing adapter.
I have decided to eliminate the springs in the steering knuckle with these pieces. They use a set screw and heavy washer to pre-load the nylon cone.
The tie rod ends for the drag link are from a Cheby application and were used in place of heim joints due to the angle from the pitman arm and steering nuckle...
