Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 05-07-2008, 08:20 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Then it will be new rotors, rebuild the calipers and x-over steering!
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #62 (permalink)
Old 05-09-2008, 06:17 PM
HRDROKN's Avatar
I just sold my old axles as a pair, so time to get that old D60 out of the truck and prepair the D80 to go under. I will be changing the rear springs to 3" wide later down the road....
Dana 60....
Dana 80.....
__________________
HRDROKN
  #63 (permalink)
Old 05-11-2008, 01:21 AM
1969F2504X4 1969F2504X4 is offline
1969F2504X4 is starting off with a positive reputation.
Awesome work!! Wish I could weld that good. One question though.............are the neighbors pissin and moanin about the noise from fabrication??
  #64 (permalink)
Old 05-11-2008, 10:02 AM
HRDROKN's Avatar
Quote:
Hmmmmm.... not to me. I try to end all work well before dusk and I usually wait till around 10am to start. I am in violation of city code.... can't have a vehicle dissmantled for more than 10 days!
__________________
HRDROKN
  #65 (permalink)
Old 05-11-2008, 05:28 PM
FirstTry FirstTry is offline
FirstTry is starting off with a positive reputation.
Sweet project, my friends got a 71 cc sb lifted up, but its just got a littel 300 6 in it, hes been wanting to do a diesel swap for a while, maybe this will be the thing that finally convices him to do it!
__________________
"BIG" Joe
This is the attitude we should ALL have
originally posted by Greywolf
"If I can really get this thing together it will either scatter itself in a million pieces or be the fastest pickup truck on earth."
  #66 (permalink)
Old 05-12-2008, 03:54 PM
davethecow davethecow is online now
davethecow is gaining momentum as a positive member of FTE.
After seeing those springs id be investing in a kidney belt...j/k.....Seems like some cities prefer there residents not to have a hobby.
__________________
Runnin thru B.L.M Fences in the Nevada Chaptor
75 f-100 short box 4x4 Ford
73 K-10 short box 4x4 Chevy
78 w-100 short box 4x4 Dodge
81 jeep wagoneer 4x4
  #67 (permalink)
Old 05-13-2008, 07:53 PM
HRDROKN's Avatar
Quote:
We will have to see how the springs ride.... I always intended on having some nice springs made for this one by National Spring. I also thought about four linking the front and rear.... but that will have to be a down the road project!
__________________
HRDROKN
  #68 (permalink)
Old 05-15-2008, 05:31 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
subscribed for sure. awsome build. hope my crew turns out like that
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #69 (permalink)
Old 05-19-2008, 01:11 PM
perky's Avatar
perky perky is offline
perky is starting off with a positive reputation.
Looks real good keep up the fine work don't rush it.A artist takes his time sculpting.
Dale
__________________
1975 F250+Supercab TrailerSpecial [And then some]
6.0Perkins Twin turboed diesel
List Mod's in Gallery
  #70 (permalink)
Old 06-04-2008, 11:22 PM
HRDROKN's Avatar
Well it has been a bit slow going.... the whole late model hub and rotor combination didn't need to be so difficult. To make a long story short.... I had a late model big stud hub on one side and an early small hole hub on the other and didn't realize it. Oh well.
Finished installing inner seals and carrier bearings.... reset the lash and now I'll get after that cone shaped pin on the knuckles, got to find me a big ass cheater pipe!
And now it is time for one of these......
__________________
HRDROKN
  #71 (permalink)
Old 06-05-2008, 11:59 AM
HRDROKN's Avatar
On another note..... Those 16.5" slot mags might be up for sale Since going to 9/16" wheel studs these wheels will have to be drilled to fit! I'm looking for a company that can do this down here in CA.... Sacramento to San Francisco area. Anyone have anything like this done before?
__________________
HRDROKN
  #72 (permalink)
Old 06-06-2008, 03:47 PM
HRDROKN's Avatar
Solution....
I found some Gorilla Duplex Mag Shank nuts in 9/16"-18 that are only .010 larger shank dia. So I will just have to ream the holes out a bit!
Quote:
__________________
HRDROKN
  #73 (permalink)
Old 06-12-2008, 12:19 AM
straightsix4x4's Avatar
straightsix4x4 straightsix4x4 is offline
straightsix4x4 is starting off with a positive reputation.
looks like there is plenty of meat on the rim to bore the holes out, keep up the good work
  #74 (permalink)
Old 06-18-2008, 07:15 PM
CSXPAID CSXPAID is offline
CSXPAID is starting off with a positive reputation.
Very cool project!!!! Can't wait to see more
  #75 (permalink)
Old 06-25-2008, 10:51 PM
just-n-time's Avatar
just-n-time just-n-time is offline
just-n-time is starting off with a positive reputation.
Great fab work man I do wish I could weld that well
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
