1969 Ford Cummins Crew Cab Conversion
Old 12-09-2010, 11:32 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
GOOD to hear!
Been busy playing with the kids, dirt bikes and other toys Mark? Been a while since I've seen any posts from you. I'm going at a snail's pace on my truck and it seems I may pass you by in completion date...
  #602
Old 12-09-2010, 11:39 AM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
I had to get a couple other projects out of the way before a little hand surgery (again). I rebuilt the motor in my 77' powerwagon and then installed a KDX220 motor in a KX125 roller. Nice little swap that was!
And the Powerwagon...
I'll have to look around and see what you been up to!
  #603
Old 12-10-2010, 05:33 PM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Twin turbos.....
Re-evaluating this project and what I really want and need don't quite line up. So I going to shelve the twins for now and just run a single... at least till I get the truck on the road and such.
Any thoughts as to running a 62/74 with ported head, cam and a 5 speed?
  #604
Old 12-17-2010, 06:07 PM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Sure wish I had wrote more stuff down... spending too much time getting caught up!
I have been working on miscellaneous items, such as steering and throttle items, which brings up an inquiry... does anyone have the linkage assembly for a P-Pump laying around? I hate to have to fab out all new stuff!
Made a new pedal mount...
And fitting the steering shaft...
  #605
Old 01-01-2011, 01:25 PM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Finished up getting the injection lines cleaned and installed along with the injectors...
  #606
Old 01-01-2011, 01:47 PM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Also been working on the dual feed lines. Got the Y block mounted... feeding a -6AN to the front and a -8AN to the side port. The Y-block is being supplied by a -10AN to the AirDog.
Waiting on fittings to finish it up....
  #607
Old 01-05-2011, 09:34 PM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Power steering issues still....
After 3 days of research... I'm giving up on the Eaton BB pump as they seem to be getting phased out.. so I have a Vickers vane pump in mind with the needed SAE "A" flange, 5gpm and 1500 psi. Just need to find a dealer to order through.
Spent the better part of yesterday out at pick n pull... to my surprise they had 5 bump sides, so I picked and pulled every miscellaneous bracket, bolt and flange that I seem to have miss placed since this project started.
Today I started on the roll bar....
  #608
Old 01-06-2011, 01:14 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Do you have your own mandrel bender?
  #609
Old 01-06-2011, 01:39 AM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
I do have one, but have not had any time to get familiar with it... so I ordered a kit as offered at Summit and Jegs.
  #610
Old 01-06-2011, 02:03 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Looks good so far. You doing a full cage?
  #611
Old 01-06-2011, 11:03 AM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Current plan is to go with a six points with two rear main hoops... so we'll see how that all goes first.
  #612
Old 01-06-2011, 11:48 AM
ChaseTruck754
Looks good! You are going one step further than I am and that is a step further than i thought you'd go. I've thought about a cage but have been avoiding doing it because I know it will snowball into something crazy. I'm trying to keep the interior stock-ish at this point. We'll see how long that lasts...
  #613
Old 01-07-2011, 02:24 AM
HRDROKN's Avatar
HRDROKN
HRDROKN is offline
Just wanted to add a little more protection to the contents... hopefully I will never need to know if it all worked out! I initially just wanted a place to tie in some shoulder strap mounts, but then one thing leads into another.
Anyone have any good cage building links?
  #614
Old 01-07-2011, 10:47 AM
ChaseTruck754
I hear ya. I'll probabyl end up adding a cage to mine, but like I said I'm sure it will snowball into a race cage - which I don't want.
What are you looking for in cage building links? A lot of the stuff i have is all "prerunner" (desert race actually) related so it's probably major overkill for what you want.
Any specific questions you are looking to answer - or just looking for pics, etc.?
  #615
Old 01-07-2011, 10:55 AM
Bill W's Avatar
Bill W
Bill W is offline
something like this?
Roll Bars/Cages
Quick Reply: 1969 Ford Cummins Crew Cab Conversion
