Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 03-15-2008, 02:56 PM
sglaine's Avatar
sglaine sglaine is offline
Crusher of B/S artist
2000 Ford F-350
sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future
Wow I am impressed with the project.....Keep up the great work
__________________
00 F350 4x4 Power Stroke 6spd drw rack body 4.10
Master Slacker #12
Leader of the New Hampshire Chapter.. Come And Join - CLICK HERE
  #47 (permalink)
Old 03-24-2008, 12:42 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
OK... so my search for that infamous Dana 60 continues. So back to work on the frame rails it is. Here are a couple pics from this weekend.
Strengthening the frame joint.....
Alittle extra clearance for the 78-79 power steering box....
Front cross member test fit...
  #48 (permalink)
Old 03-25-2008, 10:21 PM
HRDROKN's Avatar
Finished welding up both sides of the frame splice and boxed in the joint....
Same on drivers side....
  #49 (permalink)
Old 03-25-2008, 10:30 PM
HRDROKN's Avatar
Test fit the 78-79 power steering box...
  #50 (permalink)
Old 03-25-2008, 10:54 PM
dodmort's Avatar
dodmort dodmort is offline
dodmort is starting off with a positive reputation.
have you got some weight estimates on the finished product. ?
that is some thick ole stuff there.
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Guns, Guns, Guns......."Clarence Boddicker" Robocop circa 1987
  #51 (permalink)
Old 03-26-2008, 01:20 AM
HRDROKN's Avatar
Ya, it does look beefy!
Same thickness (.250) as the rest of the frame... going to cut out the drivers side like I did on the passenger side. The cross member and the the most recent steel used to box the joint is only .187 wall.
  #52 (permalink)
Old 03-26-2008, 09:19 AM
dodmort's Avatar
was wondering the weight of the truck also...
we are in the middle of a m-715 with 390 ford and 4 link all the way around.
kind of guessed the truck will weigh 6200 lbs.
the weight .25 mob for the brackets and 1/2 " thick tube for 4 link is getting out of hand in my opinion.
__________________
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
  #53 (permalink)
Old 04-04-2008, 08:13 PM
HRDROKN's Avatar
Waiting for some steel and other parts.... so I started striping the front radiator support and measuring for mounting.
  #54 (permalink)
Old 04-14-2008, 02:45 PM
HRDROKN's Avatar
Reproduction fenders.... bad idea!
My big mistake..... ordering reproduction fenders! These things just don't fit very well at all! The bad part was that when I received the fenders, I primered the back sides.... So no chance of returning! I have even tried modifying the fender for propper fit with no luck. Here is the worst area in the pic below...
Second waste of time was.... stripping the inner fenders down and repairing the rust under the battery trays, as I found some real nice inner fenders this weekend and bought them....
Misc pics fropm this last week...
  #55 (permalink)
Old 04-23-2008, 10:10 AM
HRDROKN's Avatar
Worked on the front cross member/spring hangers this week... had to take the fenders back off to get in there and measure. You know measure once cut twice
  #56 (permalink)
Old 04-24-2008, 06:45 PM
HRDROKN's Avatar
Todays progress.....
Next thing is to through that D44 on w/tires, put the motor in and load the springs to see if I like
  #57 (permalink)
Old 04-26-2008, 12:26 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold
Ive noticed when vehicles are advertised as "rust-free",often that only means that the seller is giving you the rust for free,no charge! This Crew-cab looks impressive as-is,BTW,and im interested in seeing how it finishes up,GOOD WORK!
  #58 (permalink)
Old 04-26-2008, 02:23 PM
HRDROKN's Avatar
Quote:
Ya... I got plenty of free rust with that one!
BTW the truck is in Vacaville if you're ever up this way.
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #59 (permalink)
Old 05-05-2008, 07:02 PM
HRDROKN's Avatar
This last week I worked on the power steering mount. Thought about many different ways to skin this cat, but decided that I didn't want bolts sticking through the frame.... so here's the pics. Somehow I had taken more pics during fabrication of all this, but they didn't write to my card... Hmmmmm.
__________________
HRDROKN
  #60 (permalink)
Old 05-07-2008, 08:13 PM
HRDROKN's Avatar
Finally feel like I'm getting somewhere this week.....
Still waiting on all the rebuild parts for the axle... new kingpins, spindles, bearings, u-joints and seals.
__________________
HRDROKN
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
