Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #451 (permalink)
Old 09-24-2009, 11:34 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
So I took everything back apart to do all the port matching from manifold, spacer and secondary turbo inlet... kind of time consuming, but needs to be done.
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #452 (permalink)
Old 09-24-2009, 11:48 AM
HRDROKN's Avatar
Finished up the primary turbo mount... not a lot of room to get that drain hose past the motor mount. I have two direction that I can go with it... to the stock location on the block or one of the two npt bungs that I added to the oil pan....
The mount...
__________________
HRDROKN
  #453 (permalink)
Old 09-24-2009, 11:59 AM
HRDROKN's Avatar
Finished up the primary turbo mount.....
__________________
HRDROKN
  #454 (permalink)
Old 09-24-2009, 12:10 PM
HRDROKN's Avatar
Port matched the primary turbine inlet....
__________________
HRDROKN
  #455 (permalink)
Old 09-24-2009, 12:14 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
looking GOOD!
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #456 (permalink)
Old 09-24-2009, 09:47 PM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 is gaining momentum as a positive member of FTE.
Nice port job on those...
__________________
Ford Trucks are Like Lay's Potato Chips, You can't have just 1
69 Bronco 1/2 cab, 71 Bronco Wagon, 76 Bronco , 77 Bronco 1976, F250 Highboy, 1979 F150 SB, 1979 F150 SB Mudder, 1989 F250 2wd, 1979 F350 Monster 5.9 1999 F250 SD V10, 1988 Conquest Class A
  #457 (permalink)
Old 09-25-2009, 04:29 PM
HRDROKN's Avatar
Added a strap to stabilize the setup.....
And I think I'm finished with the hot pipe and it's to the oven for curing... that should make the little woman happy. Besides whats a Wolf stove good for if I can't cure some paint!
__________________
HRDROKN
  #458 (permalink)
Old 09-30-2009, 05:14 PM
kshaneh's Avatar
kshaneh kshaneh is offline
kshaneh is starting off with a positive reputation.
WOW man, great job keep it coming
__________________
78 f150 4x4 351m c6 np205(Drowned to death)
93 Ford Bronco XLT 5.8 351C Auto
Quote:
Originally Posted by 79F150/F600 View Post
Nice job you now have yourselfa real solid and good looking truck. This thread is just the kind of inspiration I need to get me going on my body swap for my 74 highboy. Unfortunately even with doing a body swap I will have a good deal of welding to do. Your truck looks 300% better now.
  #459 (permalink)
Old 10-01-2009, 01:51 AM
HRDROKN's Avatar
Quote:
Thanks!
Things I've been working on...
I think that I have the hydroboost booster figured out, but I can't seem to identify the PS pump that I have in my pile of parts. It looks to have had a divorced reservoir and I can't find a picture on line that looks anything close? So that mystery continues...
Then I spent half of the day laying under the truck looking and measuring this four-link setup and I'm not feeling it.... there just isn't enough room on the passenger side to run that upper link anywhere but under the frame rail.... unless I do a hood stack!
It was recommended by several in the know, to do a three link with two lowers and a single off center upper. The only reason to do a four link was for the extra strength of the fourth link. So now I'm rethinking that direction.
The easiest (and less strength) of all is to just do radius arms... just don't like having only two attachment points at the frame. Think I like the three-link better.
I need to do some more calculations.... the hard part of that is trying to figure how the link geometry reacts with a leading link configuration (compared to a trailing link) and what effects that has on anti-squat. There is plenty of info on trailing links under acceleration, but I can't find any good write ups on linking the front and the effects on lift and squat.
My head hurts now.... going to bed!
__________________
HRDROKN
  #460 (permalink)
Old 10-01-2009, 10:05 AM
When you have a track bar it is like a panhard bar. === 3 link with stock rad arms. When you wake up you will see the light. Just stretch the arms 12"
__________________
  #461 (permalink)
Old 10-01-2009, 10:57 AM
HRDROKN's Avatar
Quote:
I wasn't including the panhard bar as it would be universal in all three setups. The lower links in all three configs will be aproximately 48" in length to minimize arc.
As far as which system to build revolves around 1. Safety 2.Strength 3.Maintenance
In my opinion the 4-link resolves all these. With 700HP trying to tear the front end out from under a 8000lb truck... I feel better with multiple attachment points to distribute the load. With the load spread over 4 joints @ each end, the maintenance interval is also increased.
__________________
HRDROKN
  #462 (permalink)
Old 10-18-2009, 01:27 AM
HRDROKN's Avatar
Some progress.....
I was able to get some more of the frame boxed in... this is the drivers side where I had to make clearance for the NV271 transfercase.
__________________
HRDROKN
  #463 (permalink)
Old 10-18-2009, 01:35 AM
HRDROKN's Avatar
Had to remove the bottom turbo to complete the passenger side coilover hoop....
__________________
HRDROKN
  #464 (permalink)
Old 10-18-2009, 01:42 AM
HRDROKN's Avatar
The drivers side hoop is going to take a little more work to clear the steering shaft...
I will finish this one later....
__________________
HRDROKN
  #465 (permalink)
Old 10-18-2009, 01:52 AM
HRDROKN's Avatar
I have most of my 4-link demensions resolved and the leafs come out!
__________________
HRDROKN
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
