Drill pin kit?
I've been considering a fluid damper on my mostly stock engine, as mine appears to be bulging the rubber out of the groove. You are obviously planning on some serious torque here, any reason you chose this one?
killer build
The drill pin kit is recommended for anything over 3500 RPM.... I'm not sure what it does, but it appears to add some stability to the mass, as well as eliminating the play at the mounting bolts.
The only other option is the ATI Superdamper.... looks like a real nice piece. There wasn't much time to compare as the ATI was fairly new and not a lot of guys using it yet.
As usual, very pro.
Think I'll look for a fluid damper of some sort, not quite ready to worry about that yet, but thanks fer the input.
Seems like my progress has slowed to a crawl.
Glad you're still moving forward.
__________________
1976 crew cab, 4x4, family tow monster. 97 Dodge Cummins engine doner.
Woo Hoo... took 3 hours to read all 30 pages from start to finish. Guess i am a slow reader. Don't know much about diesels but appreciate the pics and details that you and others have provided. Just wanted to say thanks for having the balls to do this, i admit this is way over my head but now i have learned something new. Just goes to show ya that just because our trucks are old, they can still be upgraded. Just my .02
__________________ 68' F250 C\S Waste's gas but hauls ass.
Any updates? Doing a wonderful job man. wish i had the resources u do
__________________
78 f150 4x4 351m c6 np205(Drowned to death)
93 Ford Bronco XLT 5.8 351C Auto
Quote:
Originally Posted by 79F150/F600
Nice job you now have yourselfa real solid and good looking truck. This thread is just the kind of inspiration I need to get me going on my body swap for my 74 highboy. Unfortunately even with doing a body swap I will have a good deal of welding to do. Your truck looks 300% better now.
I was going to work the other day and hit what looked like a 10" square box on the freeway..... well it busted the hell out of my front end, so I have been busy rebuilding the car. BMW parts aint cheap!
Of course it was a good time to add some upgrades!
ouch man good luck with the bmw.. let us kno how it comes together
__________________
Well after messing with the twins setup I figured that the primary would fit on the bottom after all... I guess taking a couple weeks off helps the thought process!
Wow man lookin god so far. Did you get the BMW fixed up?
__________________
Good job man, now u can focus ur attention to gettin the truck done
Quote:
Originally Posted by HRDROKN
thanks....
Yep BMW has new camber/castor plates, poly bushings, new lower controls and swaybars!
__________________
