Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #421 (permalink)
Old 07-23-2009, 11:13 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Had a whole day off....
Started getting the frame boxed in... this was a bit time consuming. The next sections will go easier as the frame channel doesn't taper.
I will have to work this piece in on the passenger side to give room for the exhaust to pass by....
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #422 (permalink)
Old 08-01-2009, 12:35 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
Less talk more 4 link
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #423 (permalink)
Old 08-03-2009, 12:34 PM
HRDROKN's Avatar
I had to take a break from frame and suspension work... so I worked on the timing gear cover and the clutch master cylinder actuating rod....
__________________
HRDROKN
  #424 (permalink)
Old 08-07-2009, 12:18 AM
bendog's Avatar
bendog bendog is offline
bendog is starting off with a positive reputation.
Whats the trick cover for? Timing adjustment, or didn't you put some marine cam gear or something on? Oh ya looking sweet.
__________________
1976 crew cab, 4x4, family tow monster. 97 Dodge Cummins engine doner.
  #425 (permalink)
Old 08-07-2009, 11:26 AM
HRDROKN's Avatar
Quote:
It really was designed to access a adjustable timing gear, but I wanted something to go in place of the oil fill tube as I will be adding oil fill to the valve cover. And it gives me more room for when I make timing changes with the stock gear....
__________________
HRDROKN
  #426 (permalink)
Old 08-14-2009, 09:10 PM
HRDROKN's Avatar
Scored!
Picked this NP273F up for $100.... I'm going to take the output shaft, tailhousing and fixed yoke and see if it all fits in my NP271D for a slip yoke eliminator upgrade?
__________________
HRDROKN
  #427 (permalink)
Old 08-17-2009, 11:05 PM
wantaford's Avatar
wantaford wantaford is offline
wantaford is starting off with a positive reputation.
Just tagging - Don't know what you do for a living - but your work and attention to detail is outstanding. Look forward to following this post!
__________________
1996 Ford F-350 Crew Cab 4x4, 7.5L 460 V8, Manual Transmission, Cali Emissions
  #428 (permalink)
Old 08-24-2009, 11:44 AM
HRDROKN's Avatar
Quote:
Thanks!
Updates....
I had to send the coils back to FOA to have 90* added to the reservoir attachment. As soon as they return I will be ready to move forward on it.
The motor is almost complete. I should be pre-lubing her this week, then finish the injection pump to fuel supply lines. I will be using a single turbo for now, as it looks like I'm going to have to be a bit creative to fit the twins.
I'm in the process of re-doing (3rd time) my clutch pedal. I like the feel and the ratio seems to be good, just not liking the overall look so I'm using another pedal from a Dodge application.
Boxing the frame has been a bit time consuming... mainly because I'm working around motor, trans, etc. I'm almost done with the difficult section.
On a major search for a radiator.... trying not to have to spend the big cash on a custom fit. Looking to use a aluminum crossflow, maybe with a dual pass so I'm keeping an eye on ebay and craigslist for a deal.
Thats about it...
__________________
HRDROKN
  #429 (permalink)
Old 08-24-2009, 02:14 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Good deal - another PM sent on radiators...
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #430 (permalink)
Old 08-24-2009, 02:49 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
I haven't tried it for fit yet, but I have a radiator from an '85 F250 6.9 IDI that I'm hoping to use for my swap. Rough measurements have it at 30" tall X 31.4 wide at the core, and 34" wide total to each side of the mounting brackets. Upper hose fitting is pass. side so that matches up well, lower is just to the driver's side of center so I'll need to snake an adapter over to that side around the bottom of the radiator.
It's a little wide at the bottom where it has to fit between the frame horns so I'll need to notch them, figure I'll box them in, maybe with C-channel. It's also going to be a bit wide up top...I have the core support from the same truck, I may just cut it up and combine it with the original core support (or my spare one, more probably.) Don't know if you'd consider this a feasible solution for you as well, but I think I can make it work...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #431 (permalink)
Old 08-24-2009, 03:05 PM
1974 Ford F-250
1 thing that I forgot to mention is to remember to think of an intercooler if you plan on using one. You need to find a radiator "narrow" enough that an IC will fit "around" it.
If I remember right the distance from inside to inside of the tubes on my stupid duty IC was like 30"
__________________
1970 Ford F250
  #432 (permalink)
Old 08-24-2009, 03:12 PM
TigerDan's Avatar
1968 Ford F-250
Good point...I didn't measure that as it's in storage with the engine right now...
__________________
FTE Moderator
  #433 (permalink)
Old 08-25-2009, 10:41 AM
HRDROKN's Avatar
Completed the first section of frame boxing on the passenger side. Had to make clearance for 5" exhaust for the future twin setup.
__________________
HRDROKN
  #434 (permalink)
Old 08-25-2009, 10:44 AM
HRDROKN's Avatar
Fluidampner with drill pin kit installed....
__________________
HRDROKN
  #435 (permalink)
Old 08-25-2009, 11:38 PM
bendog's Avatar
Drill pin kit?
I've been considering a fluid damper on my mostly stock engine, as mine appears to be bulging the rubber out of the groove. You are obviously planning on some serious torque here, any reason you chose this one?
killer build
__________________
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
