Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #361 (permalink)
Old 06-26-2009, 12:33 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
And here is the latest on the stand alone clutch peddle assembly..... I will add a third bearing suport to the outside of the shaft.
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #362 (permalink)
Old 06-26-2009, 02:06 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Holy freak dude, thats some serious whittling! Looks good though.
I've done an adapter thats similar for a non automotive application and used pipe flange blanks and a piece of pipe, weld it up, machine to spec. Worked awesome.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #363 (permalink)
Old 06-26-2009, 02:12 AM
You do get serious when you do something, don't you!
It looks awesome!
-Enjoy
fh : )_~
__________________
  #364 (permalink)
Old 06-26-2009, 12:39 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
yeah - that thing looks good! It gives me some ideas on how I want to mess with mine here soon
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #365 (permalink)
Old 06-26-2009, 07:27 PM
HRDROKN's Avatar
Thanks again for the comps Guys!
Anyone have any idea about the best mounting location of an AirDog 150.... closer to tank or motor?
__________________
HRDROKN
  #366 (permalink)
Old 06-27-2009, 07:50 AM
Closer to Motor!
-Enjoy
fh : )_~
__________________
  #367 (permalink)
Old 06-27-2009, 08:51 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
I agree, closer to the motor. There should be no issues with the suspension lift, drive line. I saw one where the guy mounted the filter above the front drive line and it smacked the first filter, of course leaking fuel everywhere!
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #368 (permalink)
Old 06-27-2009, 10:03 AM
HRDROKN's Avatar
Quote:
Originally Posted by Festus Hagen View Post
Closer to Motor!
-Enjoy
fh : )_~
Quote:
Crud.... I was just getting ready to mount closer to the tank as that was the input from CompD and Cummins forums.... they were saying that it is a pusher pump... maybe I just need to call PurFlo Technologies. You would think that it would be addressed in the instructions?
__________________
HRDROKN
  #369 (permalink)
Old 06-27-2009, 06:32 PM
I should of educated before opening my mouth. Arrrg!
I didn't fully understand the AirDog... I thought it was just filters, did not know it was a pump as well.
Technically the filter should be as close to the IP as possible, yet the pump should be as close to the tank as possible.
The pump type defines it's location.
A positive flow pump (like a diaphram or piston pump) can be mounted anywhere, gear/vane pumps tend to not have good suction and therefore should be mounted around fuel level.
I've got to believe they designed the Airdog to be mounted in the engine compartment.
Personally I wouldn't want my filters under the truck or that far from the motor.
-Enjoy
fh : )_~
__________________
  #370 (permalink)
Old 06-28-2009, 08:06 AM
Since the air dog is made to "replace" the lift pump and filter on the cummins, I would think it'd go in place of the stock location. Information shows the air dog is a high volume lift pump and FASS combo. Almost a must have too keep the vp 44 injection pump together but a nice upgrade for others.
I could be wrong on this one but I would want the filtered side line as short as possible to the injection pump.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #371 (permalink)
Old 06-28-2009, 11:29 AM
1974 Ford F-250
Quote:
Ok - I've looked at this pic over and over and I can't figure it out. Did this thing start as 2 pedals? Or was that a dodge clutch pedal to start with or what?
I will be doing my hydroboost soon and want to look at doing the clutch master and pedal stuff at the same time.
__________________
1970 Ford F250
  #372 (permalink)
Old 06-28-2009, 01:33 PM
HRDROKN's Avatar
That is a piece of a Dodge (could be anything similar) clutch peddle on the outside of the stock ford peddle.... I needed to get the clutch M/C attaching point more support. The M/C cannot be moved closer to the Ford peddle assembly due to the factory firewall bracing. I cut the Dodge peddle and bent it to intersect with the Ford peddle, then used the flat plate for a "cleaner look". I still need to add a outer support that is probably not really needed, but won't hurt. The M/C attachment rod is unfinished... I will add a stop to locate the M/C rod end and thread the outer for a retaining nut.
I can take some pics of the back side if that will help.
__________________
HRDROKN
  #373 (permalink)
Old 06-29-2009, 11:56 AM
1974 Ford F-250
Thnaks for the info. That is about what I thought, but the weld bead towards the top of the Ford pedal kinda threw me. Plus with your welds ground down it almost looked like that top plate work could have been factory.
So if that was the stock dodge clutch pedal on the outside - it would be where the M/C connects. Is that solid rod on it (maybe a bolt with the threads cut off and soulder left) stock? If it is a cut bolt then obviously it won't be stock, but is that the same distance as stock dodges from the clutch pivot to the M/C connection point?
More pics are always welcome!
__________________
1970 Ford F250
  #374 (permalink)
Old 06-29-2009, 06:14 PM
HRDROKN's Avatar
LOL.... I hate grinding down welds as I always feel like I'm hiding a bad weld. The plate was kind of a after thought to clean the look up.
Yep thats a bolt with the threads cut off. I will thread it after I see exactly where the M/C rad end wants to ride. The distance is close to factory Dodge... If I remember the Dodge was 2.250" and I eneded up shortening that for some more peddle swing to 2.000". I will then add a stop so that I'm not bottoming the M/C. Then I'm going to remove the rubber peddle cover and weld on some serious traction so my foot never slips off!
__________________
HRDROKN
  #375 (permalink)
Old 06-29-2009, 06:44 PM
I would have to say it's going to ride pretty tight to the right side (closer to pedal) from the looks of the alignment with the M/C mount hole. It looks pretty centered and it should be offset half the thickness of the pushrod.
However it is hard to tell the alignment via pictures.
My only concern is the swing to stroke ratio, you gave it more swing, will it still stroke the M/C fully?
The more the swing the easier it'll be to push.
Did you equal the clutch pedal with the brake pedal. So it's not higher or lower then the brake pedal.
-Enjoy
fh : )_~
__________________
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
