Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #346 (permalink)
Old 05-31-2009, 07:21 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Festus Hagen View Post
I go all the way on the downstream side, and a little under on the upstream side.
On a injected turbo'd motor Polish / Smooth flow is more effective then volume.
When I assemble, I set the gaskets on the downstream side in a tiny dab of adhesive (not silicone) on the outside of the bolt flanges and let it dry to hold the gasket right where I want it until it's bolted up.
-Enjoy
fh : )_~
OK...... so I will target a smooth transition from gasket match and do a general clean-up of the bowls and call it good. These 12ver bowls are herendous! OMFG! It's amazing the power that we still are able to push out of these motors....
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #347 (permalink)
Old 06-01-2009, 01:05 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Why, Cleaning it up would take money out of the CEO's pockets, adding a couple pounds of boost won't!
Look at the bright side, a good cleanup and polish is a simple power adder for builders!
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #348 (permalink)
Old 06-02-2009, 12:36 AM
HRDROKN's Avatar
OK... have the intake and exhaust bowls ruffed in. Not sure about these pics, but they were the best of the bunch.
Comments and suggestions....
Looking at this pic... is it safe for me to remove more material from the 7-8 o'clock are of the exhaust bowl...???
__________________
HRDROKN
  #349 (permalink)
Old 06-02-2009, 11:24 AM
HRDROKN's Avatar
I re-shot these pics....
Exhaust....
Intake.....
__________________
HRDROKN
  #350 (permalink)
Old 06-02-2009, 12:24 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Looking good. I like to smooth out/round off any sharp edges such as those I can see around the valve guide, and some of the biggest gains are to be found by simply smoothing the short side radius, I.E. the sharp transition from the bowl to the port (barely seen in the bottom pic above.) There's usually a very sharp edge left there by the factory machining process and if you spend a few minutes per port there rounding that off, it helps a bunch.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #351 (permalink)
Old 06-05-2009, 04:26 AM
HRDROKN's Avatar
Just about all done with the exhaust ports.... I still want to work the bottom of the valve guides a bit...
Comments/suggestions?
__________________
HRDROKN
  #352 (permalink)
Old 06-05-2009, 01:50 PM
Sweet!
Did you know you can build a flow bench pretty cheap... I built one for around a couple hundred bux.
-Enjoy
fh : )_~
__________________
  #353 (permalink)
Old 06-05-2009, 02:40 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
I've got a comment. Well, more of a request... Want to do mine?????
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #354 (permalink)
Old 06-05-2009, 10:39 PM
HRDROKN's Avatar
Hey a flow bench might be fun! Do you have a parts list that you can send me?
Sweet!
-Enjoy
fh : )_~
__________________
HRDROKN
  #355 (permalink)
Old 06-05-2009, 10:47 PM
HRDROKN's Avatar
Quote:
When you are ready... We can probably work out a deal.
__________________
HRDROKN
  #356 (permalink)
Old 06-05-2009, 11:33 PM
I dissembled that back in '95 when we moved out here from Cali., I still have all the gauges and equipment, boxed up though!
Check out DIYPorting.com
I like this guys write up, it's for Go-Karts, but can be easily up sized.
DIY Flow Bench
Great for port flow matching... And knowledge!
The biggest issue with DIY porting is wall thickness, thats not easy or cheap to measure, at least it wasn't back it the late 80's early 90's, I quit doing this stuff in 90 and went into the computer business, now I'm retired (Thanks M$) and returning to the love of my life ... Making things go!
(At least I will be when I get our burnt out house finished)
-Enjoy
fh : )_~
__________________
  #357 (permalink)
Old 06-11-2009, 02:22 AM
HRDROKN's Avatar
Finally got back at it...... ruffed in the intakes today. It seems that most of the information found on porting the Cummins 12 valve revolves around the exhaust ports... not much information about the intakes?
__________________
HRDROKN
  #358 (permalink)
Old 06-25-2009, 03:53 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch Ravenwood Ranch is offline
Ravenwood Ranch is starting off with a positive reputation.
all i have to say is that is so awsome, ive never seen a truck like that before
__________________
95 F350 5Speed Extra Cab Long Bed IH Powerstroke Diesel
  #359 (permalink)
Old 06-26-2009, 12:14 AM
HRDROKN's Avatar
OK.....
Just about ready to rap up this porting job....
__________________
HRDROKN
  #360 (permalink)
Old 06-26-2009, 12:26 AM
HRDROKN's Avatar
In between the porting action... I had this adapter/spool piece made to bolt the NV4500 to a NP205 (Ford case w/Dodge gears).... Then I read a thread on CompD about the cast iron tail housings, so I need to check my runout!
__________________
HRDROKN
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
