Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #316 (permalink)
Old 05-04-2009, 11:45 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Krewat View Post
Geez, did you even get a LITTLE dirty doing that?
Ya that was one of the cleaner jobs....
It was a little tricky holding the dual discs with one hand and propping the pressure plate up with the other..... sure could have used a third hand, but I don't suppose that would have went over any better with the wife!
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #317 (permalink)
Old 05-06-2009, 12:16 AM
HRDROKN's Avatar
Got the fith gear nut all torqued today.... hit her with 300ft/lbs and red locktite, cranked the set screws and peened the lip of the nut into the slot in the shaft. So we will see how this works out... if it comes loose then I'll put a torgue king shaft in it. Cast iron tail housing all buttoned up....
Also got some work done on the lower coilover mounts.....
__________________
HRDROKN
  #318 (permalink)
Old 05-06-2009, 11:03 PM
HRDROKN's Avatar
Well with a little help from the wife (needed a hydraulics op) got the trans in today....
Hydraulic ops viewpoint... nothing like spending time together.
__________________
HRDROKN
  #319 (permalink)
Old 05-06-2009, 11:36 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
What bell housing did you wind up using??
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #320 (permalink)
Old 05-07-2009, 02:18 AM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
man i would love to take my truck down to the point where there is NOTHING in it and start over. so i bet you covered it but what are you doing for new wireing?
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #321 (permalink)
Old 05-07-2009, 03:38 AM
HRDROKN's Avatar
Quote:
-Enjoy
fh : )_~
Stock Dodge bellhousing from 94 -01 or 03...
Did a quick tape measure before sliding her in.... something like 7.00" to pilot bearing and the trans had around 6.750" stick out not including the pilot shaft... about another 1" there....
__________________
HRDROKN
  #322 (permalink)
Old 05-07-2009, 03:40 AM
HRDROKN's Avatar
Quote:
I have a (think it is) 18 circuit EZ-Wire kit ready to go....
__________________
HRDROKN
  #323 (permalink)
Old 05-07-2009, 11:10 AM
Thanks hrdrokn,
Sure is looking sweet ... I do like the blue, though it's going to be hard to keep clean, it sure looks sharp.
I see something trying to hide up there under the dash ... A Wiper Motor!
Sure can't wait till I finish my current project (Our burnt out house rebuild) so I can start on mine.
Been collecting parts though, so I guess thats a start!
-Enjoy
fh : )_~
__________________
  #324 (permalink)
Old 05-08-2009, 08:23 AM
FordRiotStarter1992's Avatar
FordRiotStarter1992 FordRiotStarter1992 is offline
FordRiotStarter1992 is starting off with a positive reputation.
dude i cant wait to see this thing when its finished it is gonna be awsome
  #325 (permalink)
Old 05-09-2009, 05:12 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
Quote:
Make sure to post how that works out. I'm looking to re-wire my 77 F-250 with a universal kit.
__________________
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 (Work in progress)
  #326 (permalink)
Old 05-10-2009, 08:17 PM
soondg's Avatar
soondg soondg is offline
Pa. Chapter Slave
soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of soondg has much to be proud of
Rockin, I've been following this thread and am really impressed with what your doing. I have plans in the future to do my Bronco over and convert it to diesel. A Cummins warehouse and shop is right around the corner from me along with Jasper, when I have enough cash stashed I'll go around there and see what kind of deal I can get. I'm still not sure whether I want to go with the Cummins or the International. A member of the Pennsylvania Chapter works in association with Ford on their diesels. Paul Freda of Blue Diamond Parts LLC, A Ford Motor Company/International Truck Engine Corporation Joint Venture.
I'm limited to what I can do physically so I'll have to enlist others help when I do start the project. Maybe when your done you can hook up with SteveBricks and come out to the annual Mid-Atlantic meet at the All Truck Nationals in Carlisle, Pa. to show off your handy work. I'm sure the truck lovers there would really appreciate the work your doing.
__________________
Joe
STUFF IS COOL-TORQUE PULLS MORE STUFF TORQUE IS COOL
Pennsylvania Chapter, Home of the Mid Atlantic Meet JOIN US HERE!
2010 MIDATLANTIC MEET, CARLISLE, PA ALL TRUCK NATIONALS AUGUST 6--8, 2009 CLICK HERE
  #327 (permalink)
Old 05-13-2009, 01:12 AM
HRDROKN's Avatar
Quote:
I will do that.... just looking at the kit, it looks real nice! Quality wire and all..... and certainly was a great price compared to painless!
__________________
HRDROKN
  #328 (permalink)
Old 05-13-2009, 01:24 AM
HRDROKN's Avatar
Hey Joe...
I would love to head out that way when she is done..... the wife is saying ya right now! LOL.
The Bronco sounds like a nice project! I have always been a fan of the early Broncos. Depending on your goals with that project... I like the idea of a 4BT for Broncos and Jeeps! You can get 300+ HP out of a 4BT fairly easily, liller torque and great fuel mileage!
Anyway.... good luck with your project and I'll be looking forward to seeing it begin!
Mark
__________________
HRDROKN
  #329 (permalink)
Old 05-13-2009, 01:32 AM
HRDROKN's Avatar
Just got off graves this morning..... took a nap, had some lunch with the little woman, took her for a country ride on the Harley, came home and started working on that hydraulic clutch.
As suspected that firewall needed some reinforcement! I also found my peddle stroke to be too short for my liking. So I decided to pull the whole assembly out and build it as a stand alone solution and then bolt back to the firewall.
__________________
HRDROKN
  #330 (permalink)
Old 05-13-2009, 07:58 AM
very cool this is givin me alot of ideas about my truck
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
