Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #301 (permalink)
Old 04-17-2009, 01:34 AM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by brownfoot View Post
45/64 is the correct one, Dorman part # 555082..................RockAuto price $0.61 each the engine takes 3...............a little less than $16
btw, $5 buys a pack of 10, local NAPA should have it too
Oh ya...... YOU ROCK!
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #302 (permalink)
Old 04-17-2009, 01:35 AM
HRDROKN's Avatar
Was going to drop the short block in today, but decided that now would be a good time to get the coilover hoops in place!
A couple of issues did come up...
Clearance for the steering box.... I will cut that tab off and use a .500" spacer. That should give me enough room.
Deciding how I want to do this....
Results....
Besides the steering box clearance.... the other issue is whether or not these hoops will interfere with my twins?
Always room for a big single?
__________________
HRDROKN
  #303 (permalink)
Old 04-17-2009, 01:17 PM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
This is one of the coolest builds I have ever seen. You are pretty much my hero right now. Wish I could make my truck look that good.
  #304 (permalink)
Old 04-20-2009, 09:24 PM
HRDROKN's Avatar
Ok, so here is the deal.... the coilover hoops really aren't my problem as I can get the compressor piped up and over and around...
The problem is the exhaust of the primary turbo on the bottom. If I run a 2nd gen exhaust manifold that center mounts the top turbo, then the exhaust outlet on the bottom is about 3 inches from the adapter plate....
__________________
HRDROKN
  #305 (permalink)
Old 04-20-2009, 09:25 PM
HRDROKN's Avatar
So can a 3rd gen style exhaust manifold be used? I think that the ports are a different shape... The thought is if I could move the whole assembly forward. Then I may have enough room for 5" downpipe..
Then my filter is in the way..... how does a 3rd gen do this?
__________________
HRDROKN
  #306 (permalink)
Old 04-21-2009, 07:22 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
Block off the filter and use remote filters where they will not be in the way of anything.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #307 (permalink)
Old 04-24-2009, 04:17 PM
HRDROKN's Avatar
So while I consider all that twin stuff.... I got the transmission just about all back together... Also looking into a custom adapter (spool piece) to tie that NV4500 with the NP205. I think it will be the cleanest approach.
__________________
HRDROKN
  #308 (permalink)
Old 04-27-2009, 01:26 PM
80F100man 80F100man is offline
80F100man is starting off with a positive reputation.
You, my friend, are a true conversion 'thinking machine'.........I believe you could do nearly anything you set your mind to mate...........
__________________
Life is what you make it, so make it good for yourself .
  #309 (permalink)
Old 04-27-2009, 02:09 PM
HRDROKN's Avatar
Thanks Bro!
Quote:
__________________
HRDROKN
  #310 (permalink)
Old 05-02-2009, 11:26 AM
HRDROKN's Avatar
Even though it was a day spent with the little woman...... she went to the store and I ran into the garage and installed the clutch! ....
Yep, I got busted under the truck when she returned.... and got the Honey, you said.... blablablabla.... time with me speach.
__________________
HRDROKN
  #311 (permalink)
Old 05-02-2009, 01:22 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Geez, did you even get a LITTLE dirty doing that?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #312 (permalink)
Old 05-02-2009, 08:44 PM
sglaine's Avatar
sglaine sglaine is offline
Crusher of B/S artist
2000 Ford F-350
sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future
Very nice project..I 'm impressed
__________________
00 F350 4x4 Power Stroke 6spd drw rack body 4.10
Master Slacker #12
Leader of the New Hampshire Chapter.. Come And Join - CLICK HERE
  #313 (permalink)
Old 05-03-2009, 02:12 AM
rustyrelic rustyrelic is offline
rustyrelic is gaining momentum as a positive member of FTE.
[quote=HRDROKN;7455075]Even though it was a day spent with the little woman...... she went to the store and I ran into the garage and installed the clutch! ....
glad I'm not the only one that gets the evil eye when cought under a truck!
  #314 (permalink)
Old 05-03-2009, 02:45 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
Quote:
i get that look too but it is normaly by a cop and it wasnt my truck....
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #315 (permalink)
Old 05-03-2009, 05:36 PM
billnuke1's Avatar
billnuke1 billnuke1 is offline
billnuke1 is starting off with a positive reputation.
Next time say "honey, pass me the 9/16ths"... Voila! Time spent together!
__________________
[/SIGPIC]2000 Excusion LTD 4X4 3.73 V10 gas
1990 F250 Ex Cab HD 4X4 (sold)
2003 Subaru Outback
1999 Dodge Caravasn Sport
1989 Kawaski Vulcan 1500(butt ugly- but fast)
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
