Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 10-28-2007, 05:29 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Working on new frame rails....
  #17 (permalink)
Old 10-31-2007, 10:14 AM
HRDROKN's Avatar
A little more progress on the frame rails yesterday....
  #18 (permalink)
Old 11-05-2007, 09:03 PM
HRDROKN's Avatar
Picked up some 2001 Ford Superduty (Excursion?) springs today. I will use these to fabricate the new spring mounts. The longer length will give me a much better ride then the old shorter springs.
  #19 (permalink)
Old 11-05-2007, 09:24 PM
throttle's Avatar
throttle throttle is offline
throttle is starting off with a positive reputation.
Great work, I wish I had the skill and tools to do stuff like that! can't wait to see the finished project.
  #20 (permalink)
Old 11-11-2007, 02:33 PM
HRDROKN's Avatar
Waiting for some steel to show up so I can finish off the frame and spring mounts... so I been getting back to working on the cab floor and body mount...
  #21 (permalink)
Old 11-11-2007, 02:34 PM
HRDROKN's Avatar
Interior passenger side progress....
  #22 (permalink)
Old 11-13-2007, 04:38 AM
wayneasbell wayneasbell is offline
wayneasbell is starting off with a positive reputation.
I found this on craigslist
http://atlanta.craigslist.org/car/469936523.html
  #23 (permalink)
Old 11-21-2007, 01:26 PM
HRDROKN's Avatar
Well I've been a bit stagnant on this project... the holidays and kids got the best of my time.
I have all the information for mounting the 01' Superduty front springs... then I was thinking about the spacing? The 69' is set up at 32" ... I'm not sure what my new (later model) Dana 60 front axle will have? Maybe 34" or 36"? So I have to figure out if I can change the spring perch on a later model kingpin D60 without re-tubing the axle? Does the cast perch on the pumpkin offer enough room to narrow the spring spacing to 32"? Or do I need to set my spring eye mounts wider?
Hmmmmmm....
  #24 (permalink)
Old 12-02-2007, 09:15 PM
ash_flat_diesel ash_flat_diesel is offline
ash_flat_diesel is starting off with a positive reputation.
Maybe you have already figured this out but the 78-79 have the correct mounting pad width. I couldn't find one (cheap enough) but got a deal on the later one. I had already fabbed up a "crossmember" before under the frame to lower the spring mounts for some more lift. I just redid this again & moved my springs outside the frame & built mounts for the shackles under the cab on the outside. kinda like the rear springs. Good luck with the rest of your conversion! I am starting mine now. I am going to get me a rusty cab cowl for clearance like I see in your pics, easier than moving the cab a couple times. My motor has a front mount, I may cut that whole crossmember out like you did & build a new one up front & use that for the motor mount also.
  #25 (permalink)
Old 01-03-2008, 05:00 PM
Bart8109 Bart8109 is offline
Bart8109 is starting off with a positive reputation.
Cool project.
  #26 (permalink)
Old 01-04-2008, 10:45 AM
HRDROKN's Avatar
Quote:
Originally Posted by Bart8109
Cool project.
Thanks!
Sorry no updates Guys.... I have decided to go the 78-79 route for the D60 front end, so now I'll just have to keep an eye out for a good deal.
  #27 (permalink)
Old 01-04-2008, 11:35 AM
Ya, the '73-'79 platform offers some better upgrades. I've a '68 F250 and a '76 F100, the upgrades I like, but the styling of the bumpsides I prefer. Good luck.
  #28 (permalink)
Old 01-10-2008, 12:23 AM
drews_79_ford drews_79_ford is offline
drews_79_ford is starting off with a positive reputation.
anyone interested in doing a cummins swap should check out this site www.fordcummins.com
  #29 (permalink)
Old 01-22-2008, 08:16 PM
HRDROKN's Avatar
Detroit Lockers.... NOT!
Well, I just discovered this weekend that the axles that came with the truck did not have Detroit Lockers as they where advertised. So this really sucks as I was planning on selling the axles to offset the cost of upgrading. Now what?
Rear....
Front...
  #30 (permalink)
Old 01-22-2008, 10:30 PM
dodmort's Avatar
dodmort dodmort is offline
dodmort is starting off with a positive reputation.
just finished converting my dana 60 front end and dana 70 rear to lockers. this truck is a m715 army. but. the change out was a doable deal with the shop press and a bearing puller from Harbor. few seals and gaskets but easily a weekend project....
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Guns, Guns, Guns......."Clarence Boddicker" Robocop circa 1987
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
