Damn man, u got urself 1 hell of a project, ur doing an awesome job!! Keep Up the good work
__________________
78 f150 4x4 351m c6 np205(Drowned to death)
93 Ford Bronco XLT 5.8 351C Auto
Quote:
Originally Posted by 79F150/F600
Nice job you now have yourselfa real solid and good looking truck. This thread is just the kind of inspiration I need to get me going on my body swap for my 74 highboy. Unfortunately even with doing a body swap I will have a good deal of welding to do. Your truck looks 300% better now.
What a job! I'm done for the most part with the pump assembly...
This brownish orange (not the rust) goo is a sample of why my rack was stuck... It looked like glue, but I guess it was just gelled diesel fuel. I think if I would have ran this pump in this condition, I think that I would have been asking for problems....
What's the difference between these "ballistic" joints and a standard heim joint - bot price and performance wise???
__________________ Have you flown a ford lately? 1938 Ford Pickup = hot rod
1970 Ford F250 long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cabthread in "motor swap" forum 1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
The Ballistics are rebuildable and for the 1.25x12's they are $40 campared to about $70 for a heim... the ones with the bushings are a little cheaper. both have forged 4130 bodies. I thought that I would use the bushings on one end to isolate a little road noise.
I get the bushing ones - I'm just wondering what makes up the ballistic ones. I take it they are not a spherical bearing like a heim?
The spherical bearing in a heim is the same as one in a uniball. The price breakdown on heims is typically based on materials (4340, 4130, whether they are teflon lines, etc., etc.) I'm just not sure how they can cut half the cost out of good heims while still using good materials. There are 1.25" heims out there for $40 ea. but I would never run them on a truck application...
From Ballistic... I was a little off on the specs.
Quote:
The 2.63" Forged Chromoly Ballistic Joint is made to be the ultimate in durability and ease of use. 100% made in the USA, this joint was manufactured and designed for military use and quality, and meets all MIL-SPEC standards. Forged from solid 4140 steel, the forging is then quenched, tempered and then normalized in a dedicated heat treating facility, providing a yield strength of 208,000 psi and a tensile strength of 238,000 psi! Finish machining is performed after heat treat to ensure a perfect fit.
Quote:
Using Nylatron GS races with nickel plated bearings, these joints are smooth, long lasting and quiet. The 2.63" Ballistic Joint uses no snap rings to retain the races, instead a retainer is forged into the housing. The opposite side uses a threaded spanner nut and set screw. Also, we've added a lot of material to the grease zerk / set screw area to add a much greater resistance to splitting. Any play that might develop over time can be removed by adjusting the spanner nut. All forged joints are clear "silver" zinc coated.
cool deal - thanks for that. These might work pretty well for your application!
