Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #136 (permalink)
Old 09-18-2008, 09:48 PM
HRDROKN's Avatar
HRDROKN HRDROKN is offline
HRDROKN is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BradyCouchman
thats gana look interesting untill you get the carpet and headliner in... will the side of the cab be spray lined? or jsut the top and bottom?
Quote:
Originally Posted by ChaseTruck754
I plan on doing both the inside and underside of mine. Up the firewall on both sides, and probabyl up the back wall on both sides. Still deciding where to "cut" it along the side - but I most likely won't go up the B-pillars at all.
You thinking kind of the same thing - or less spray?
Well this one has been tossed around a bit also.... what I have decided on is to spray the firewall all the way up under the metal dash, the front pillars, the middle pillars and the back wall all the way up and around the head liner trim.
I'm thinking, color match (I guess I'll stick with a red) the doors and maybe spray line the door inserts w/line-x (black).
Maybe charcoal gray headliner and carpet.... do something black and red or charcoal and red with the seats?
__________________
HRDROKN
1969 Ford Crew Cab Cummins conversion,
http://www.ford-trucks.com/forums/66...onversion.html
  #137 (permalink)
Old 09-19-2008, 11:06 AM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
that will be a nice looking truck....
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #138 (permalink)
Old 09-22-2008, 02:00 PM
HRDROKN's Avatar
OK... so she is off to have the interior spray lined. I will have her back tomorrow afternoon. At least this gives me a chance to get my driveway cleaned up! And the garage... can't seem to find anything anymore!
__________________
HRDROKN
  #139 (permalink)
Old 09-22-2008, 02:03 PM
looking good...did you look at the "we come to you" sprayers?
__________________
SoCal FTE Member
  #140 (permalink)
Old 09-22-2008, 04:52 PM
HRDROKN's Avatar
Quote:
Shoot.... never even heard of them. Sure would have been convenient though!
__________________
HRDROKN
  #141 (permalink)
Old 09-22-2008, 04:53 PM
my dad has a pantera and had his engine bay sprayed while he had the motor out and they came to him to sparay it....
__________________
SoCal FTE Member
  #142 (permalink)
Old 09-22-2008, 05:15 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Damn - I never heard of that either. I guess it wouldn't be too hard though. Just throw the spray gun and the barrels of material on a trailer.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #143 (permalink)
Old 09-22-2008, 06:23 PM
Quote:
yup thats what they did, brought plastic and tape with them covered everything, even did it in the garage and covered it up to, made a little mini paint booth, and cleaned everything up and left. it works out better for them because most of the time the gas and what not is cheeper then renting a building to do it all in. this guy worked out of his house.
__________________
SoCal FTE Member
  #144 (permalink)
Old 09-23-2008, 09:20 PM
HRDROKN's Avatar
Truck back from the local bedliner establishment....
Looks too nice to cover up! Now the trick will be keeping it clean?
__________________
HRDROKN
  #145 (permalink)
Old 09-23-2008, 10:22 PM
dt75flh's Avatar
dt75flh dt75flh is offline
dt75flh is starting off with a positive reputation.
Very Nice!!!!
__________________
08 job 1 F350 4x4 CC/LB King ranch 35"s 4.10's 60 gal fuel tank
71 Mach 1 with 1990 FI/AOD 5.0 HO motor
96 Bronco XLT 5.8 32's
85 Toyota PU rock krawler with dual cases, detroits
  #146 (permalink)
Old 09-24-2008, 10:57 AM
looks very nice...looks like you got your self a helper there...
__________________
SoCal FTE Member
  #147 (permalink)
Old 09-26-2008, 01:06 PM
HRDROKN's Avatar
OK.... so the truck has a new home and we have a new house!
__________________
HRDROKN
  #148 (permalink)
Old 09-26-2008, 01:12 PM
your lucky that it isnt a long bed (i know no long bed 4X4 crews but) it wouldnt fit in there....if it is a standerd depth (>20 feet)....because my crew long bed is just to long to fit...
__________________
SoCal FTE Member
  #149 (permalink)
Old 09-26-2008, 01:37 PM
Steilenberg's Avatar
Steilenberg Steilenberg is offline
Steilenberg is starting off with a positive reputation.
That is too sweet... thanks for the peeks...
Washing that one out after a day in the woods will be great....
  #150 (permalink)
Old 09-26-2008, 01:41 PM
1974 Ford F-250
inverst in a set of wheel dollies so you can slide that thing from side to side and still use that door to the house. I've got 6 of those wheel dollies and use them for everything!
__________________
1970 Ford F250
Tags
1969 , 1972 , 69 , cab , california , cost , cummins , engine , f150 , f350 , fit , ford , fram , swap , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
