fuel rail pressure
From my experience, I am not a Ford Tech, but a Deere (John Deere) Tech, we use these new fuel systems and are running Tier III engines (super emission controls), a 5 volt out signal from the sensor would cause a circuit fault and the truck probalby wont run... if you are thinking of jumping the sensor, we have had some people try this and just ends bad causing the engine to run very poorly and wont go more than an idle. I am just speaking from my experience but a HPCR engine knows a desired and absolute pressure and they have to be within a certain range for the engine to run right. This causes a problem if you modify the sensor voltage to read higher than the engine wants to see.
I know I am going on assuming that you are trying to get more power. Our engines run about 25,000 psi fuel rail pressure under a full load. So that would probably be around 4.5 volts which is usualy the max range for a 5 volt sensor system.
Bret4207
04-25-2016 06:16 PM
