Cold Turbo Sound??? - Ford Truck Enthusiasts Forums
Cold Turbo Sound???
Old 10-22-2007, 11:08 AM
StrokeThis96's Avatar
StrokeThis96 StrokeThis96 is offline
StrokeThis96 is starting off with a positive reputation.
Cold Turbo Sound???
I started my 96 PSD this morning at about 34 degrees. I let it warm up for about 15-20 mins. when i took off the turbo and exhaust pipe were makin a wierd sound, almost like there was something stuck in the pipe. wasnt a whistle like normally on my straight pipe, but more of a blowing sound like an air compressor valve being opened. when i was goin about 25mph it was doin same thing and untill i stepped on it a little more the turbo made the normal whistle sound like normally it does but after i let off it started to whoooosh again. is it a problem with my hpop to the turbo or is it my ebpv??? or is it another problem??
Old 10-22-2007, 11:14 AM
250turbo 250turbo is offline
250turbo is starting off with a positive reputation.
i bet it is your ebpv.
Old 10-22-2007, 11:18 AM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
It's your ebpv. Just unplug it and forget about it. It's a two wire plug screwed to the base of the turbo.
Old 10-22-2007, 11:19 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
X2
Bill
Old 10-22-2007, 02:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Arrow
Rigth here:
Old 10-22-2007, 03:59 PM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
HA HA I had the same noise, even louder when I put on the AFE ,now that I unpluged the ebpv noise is gone
Old 11-30-2007, 03:06 PM
RÖENTGEEP's Avatar
FOREIGN GURU
this is the EPBV
Old 11-30-2007, 03:12 PM
hoodjason hoodjason is offline
hoodjason is starting off with a positive reputation.
What does EPBV stand for and what does it do? I have the same problem.
Old 11-30-2007, 03:42 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Its not a problem, its a built in valve to increase EGTs at idle/low speed to warm the engine up faster, they generally work, but can get annoying like that
Old 11-30-2007, 03:54 PM
plowhand's Avatar
Playing in the Dirt
Like Lead Head said. EBPV = Exhaust Back Pressure Valve
Old 11-30-2007, 06:03 PM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
So, why unplug it if the trucks operate better at a hotter temp?
Uh, thought coming ... you guys probably don't live in the cold areas?
I hear it only in the AM and then it goes away. The more heat I can get the better to start burning veggie.
Old 11-30-2007, 06:06 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Exclamation
I have read that the EBPV was a wasting time engineers. Most people has it unplugged and no any problems. And other has gutted it for always.
Old 11-30-2007, 06:07 PM
RÖENTGEEP's Avatar
FOREIGN GURU
But you also can canvert it to a exhaust brake, and works very well and cheap.
Old 11-30-2007, 07:05 PM
glasseater glasseater is offline
glasseater is starting off with a positive reputation.
it barely does anything... it's been in the 20s and under already here.. with mine unplugged it warms up just the same as it always did....
Old 11-30-2007, 09:02 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
The valve does very little of what it was designed to do. If it malfunctions and stays closed it will cause low power and high EGT which could hurt the engine and turbo. The valve only aids in cold start up warming not operating temps.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
