1991 F150 4EOD tires, shifting, speed sensor, speedometer
I have the above mentioned truck. It came with the oversized tires, shifted rough and a speedo that floated at 35 through 45 mph and beyond. I switched out the 18 tooth speedo tail gear for a 16, this eased the shifting but it caused the speedo to lay down until 25 (est.) and moves slowly jumping its way up. It never reaches the real speed of the truck's moving speed, and the downshift seems to be really quick downshifting out of overdrive. I changed out the speed sensor on the transmission. This didn't hurt, but it didn't help either. It runs well through the gears, except for the down shifting out of overdrive. Does the speedo control the shifting in some manner or is the problem in the belly of the beast's transmission>
In 1991, the speedometer was mechanical and has nothing to do with the tranny. You might have a bad speedo cable or the speedometer itself isn't working right. If you pull the gauge cluster, you can turn the speedo with a drill and you should be able to figure out which is bad.
As for the tranny not shifting right, can you explain more about that? I'm not quite sure I follow.
the transmission shifts smoothly and correctly 1, 2, 3, overdrive on a flat / level road. When I apply any sort of acceleration/load the transmission will drop out of overdrive. It seems a little touchy or quick to react. The shift is passive yet I can see the tach jump. When I ease up it drops back into overdrive. It is the same with a grade. Is there a "drop down/ kick out" switch for the overdrive.
well, it's a stock 3.08 gear. A little time, and maybe I'll get use to the shifting. I thought that there might be a setting or chip somewhere that needed to be changed out because of the tires. thanks for your help. I'll pull the speedor and look it over tomorrow. Question. Doesn't the speed sensor work off the movement of the cable
juiceymustang
20
07-15-2014 03:30 PM
overhaulin
25
07-15-2014 12:37 PM
seebeexee
06-09-2013 09:32 PM
Ddaybc
06-01-2013 10:02 PM
