Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-20-2007, 09:08 PM
MrPebodie is starting off with a positive reputation.
Very strange feeling when brakes applied
Has anybody put on their brakes while turning at a slow speed and felt like one side was kinda on a gravel type surface. This happened to me today while I was parking my wife's 02 Escape 3.0 XLT. It did not happen again when I tried the same parking move. It feels as if the front drivers wheel is braking on a bunch of loose sand gravel type of surface for about two to three feet before final stop. It has done this before but it was raining and I just thought it was my driveway which has a small loose rock type of covering. I have found many answers to other problems on this site but cant find anything on this one. Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-20-2007, 09:21 PM
sfcwoodret is starting off with a positive reputation.
The calipers on the drivers side wheel may not applying the disk brakes evenly on the rotor.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #3 (permalink)
Old 10-21-2007, 11:56 AM
Thanks for the advice. Just pulled off the caliper and was giving a good look over around the area and noticed the abs ring on the axle has a crack in it and will move when I push on it. What would be the best way to fix the ring and would this cause the funny feeling?
  #4 (permalink)
Old 10-31-2007, 07:23 PM
Stosh is starting off with a positive reputation.
Brakes
I just had my vehicle inspected today and I have the same problem. They said they couldn't replace just the ring. Apparently you have to replace the entire axle to fix the problem. Roughly $160.00 an axle plus labor. OUCH My ABS light goes on and off while driving. When the light is on the ABS isn't working. If the light turns off when I'm braking or making a right turn it causes the ABS to engage and causes the wierd brake feeling.
  #5 (permalink)
Old 10-31-2007, 08:38 PM
aquanaut20's Avatar
aquanaut20 is starting off with a positive reputation.
Have you tried "JB Weld", have fixed a couple and the cost is less than $5.00, if it doesnt work, what are you really out??
  #6 (permalink)
Old 10-31-2007, 09:03 PM
No, I never even thought of trying something like that. Good point, what do I have to lose.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
