air filter minder
Old 10-20-2007, 06:25 PM
the winemaker's Avatar
the winemaker
the winemaker is offline
Question air filter minder
changed my air filter (stock) today. air filter minder said to push to reset BUT it still shows a little yellow............is this normal or have I in fact not reset? thanks the winemaker...2003 f350 4/4 6.0psd kr
Old 10-20-2007, 06:30 PM
doubledee715's Avatar
doubledee715
doubledee715 is offline
the filter minder said to push the reset button?? Why did you reset it? How full was it?
Old 10-20-2007, 06:34 PM
the winemaker
doubledee..thanks for reply...yes on end of filter minder to reset push so i did..it was about in same spot with the old filter...but since i plan on a long trip thought i would change filter....I kept old filter
Old 10-20-2007, 06:39 PM
F250FarmBoy's Avatar
F250FarmBoy
F250FarmBoy is offline
mine always showed a little bit of yellow. How many miles did you use the filter, because mine has ~60000 MILES and never moved. Maybe the filter minder is faulty.
Old 10-20-2007, 06:43 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
depends where you drive farmboy, lots of gravel roads would probably go through filters quicker of course, where as pavement will take a lot longer to go through one
Old 10-20-2007, 06:51 PM
the winemaker
f250farmboy...old filter did not have that many miles on it (2yrs and 34000kms..21000miles) but as i say held on to old filter...minfer shows a start of yellow the winemaker
Old 10-21-2007, 02:27 AM
blackhat620's Avatar
blackhat620
blackhat620 is offline
Filter minder will move slowly until it gets fairly close to being full. The OEM Dondaldson Powercore can hold 3+ lbs of dirt and others have reported going 80K miles before changine.
Old 08-12-2010, 09:18 PM
joe blow's Avatar
joe blow
joe blow is online now
any idea on a part number for this?
Old 08-12-2010, 09:46 PM
danocross's Avatar
danocross
danocross is offline
Somebody who knows please correct me if need be, but I changed mine at 60,000 and I didn't need to. The instrument panel has an icon that will tell you when, and the filter minder should reflect that also. So changing it early is just kind of throwing away good money. I drive on lots of dirt roads, so I just figured it was due, the filter needed changing a lot more on my 7.3. This Donaldson filter is great.
Old 08-12-2010, 10:52 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Ford: 5C3Z-9N622-A
Motorcraft: FA-1784
SRP: $34.36
SkiPow
1999 to 2016 Super Duty
01-22-2017 10:27 PM
Singlecoil
10-21-2016 09:09 PM
cj50
04-09-2015 09:40 AM
Movingsolution
6.4L Power Stroke Diesel
05-04-2014 10:13 PM
Tact
17
11-13-2013 09:34 AM
Quick Reply: air filter minder
