air filter minder - Ford Truck Enthusiasts Forums
air filter minder
Old 10-20-2007, 07:25 PM
the winemaker the winemaker is offline
the winemaker is starting off with a positive reputation.
Question air filter minder
changed my air filter (stock) today. air filter minder said to push to reset BUT it still shows a little yellow............is this normal or have I in fact not reset? thanks the winemaker...2003 f350 4/4 6.0psd kr
Old 10-20-2007, 07:30 PM
doubledee715's Avatar
doubledee715 doubledee715 is offline
doubledee715 is starting off with a positive reputation.
the filter minder said to push the reset button?? Why did you reset it? How full was it?
Old 10-20-2007, 07:34 PM
doubledee..thanks for reply...yes on end of filter minder to reset push so i did..it was about in same spot with the old filter...but since i plan on a long trip thought i would change filter....I kept old filter
Old 10-20-2007, 07:39 PM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
mine always showed a little bit of yellow. How many miles did you use the filter, because mine has ~60000 MILES and never moved. Maybe the filter minder is faulty.
Old 10-20-2007, 07:43 PM
rollerstud98's Avatar
rollerstud98 rollerstud98 is offline
rollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud of
depends where you drive farmboy, lots of gravel roads would probably go through filters quicker of course, where as pavement will take a lot longer to go through one
Old 10-20-2007, 07:51 PM
f250farmboy...old filter did not have that many miles on it (2yrs and 34000kms..21000miles) but as i say held on to old filter...minfer shows a start of yellow the winemaker
Old 10-21-2007, 03:27 AM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Quote:
Filter minder will move slowly until it gets fairly close to being full. The OEM Dondaldson Powercore can hold 3+ lbs of dirt and others have reported going 80K miles before changine.
Old 08-12-2010, 10:18 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
any idea on a part number for this?
Old 08-12-2010, 10:46 PM
danocross danocross is offline
danocross is starting off with a positive reputation.
Somebody who knows please correct me if need be, but I changed mine at 60,000 and I didn't need to. The instrument panel has an icon that will tell you when, and the filter minder should reflect that also. So changing it early is just kind of throwing away good money. I drive on lots of dirt roads, so I just figured it was due, the filter needed changing a lot more on my 7.3. This Donaldson filter is great.
Old 08-12-2010, 11:52 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
Quote:
Ford: 5C3Z-9N622-A
Motorcraft: FA-1784
SRP: $34.36
6.4 Filter Minder Movingsolution 6.4L Power Stroke Diesel 5 05-04-2014 11:13 PM
stock air filter intervals / minder question enormiss 1999 - 2003 7.3L Power Stroke Diesel 13 04-16-2014 05:23 PM
Free Air Filter minder from 02 snakedoc 1999 - 2003 7.3L Power Stroke Diesel 6 11-29-2011 12:00 AM
Air filter minder R-T0r21on 6.4L Power Stroke Diesel 4 01-19-2011 04:25 PM
Air filter minder won't reset superv10 6.0L Power Stroke Diesel 3 08-30-2007 06:12 AM
Tags
2004, 350, 60, 60l, air, button, buy, diesel, f250, f350, filter, ford, minder, reset, thing, whats, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
